Hot Northstar - Please help ! - Page 10
Page 10 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 136 to 150 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; Ok so I was checking the water pump belt I changed the other day and the belt must be rubbing ...
  1. #136
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    Ok so I was checking the water pump belt I changed the other day and the belt must be rubbing the wrong way.in the pic you can see the top outer edge is white.I doubled checked the belt is on the pulleys right.when I changed the belt I took the tensioner pulley off.when tightening the tensioner pulley does it have to be adjusted ? The belt I used was from napa.also i'm trying to check my coolant mix with the floating disc thing, are these things accurate? Also my coolant looks more watery Color with a light orange color .
  2. #137
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Re: Hot Northstar - Please help !
    The white you see is the edge of the Kevlar braid molded into the belt - that braid is what does the work, not the rubber. Normal. If the belt is in the correct 3 grooves on the drive pulley, tensioner pulley, and water pump pulley then it's OK. The tensioner is spring loaded and totally self-adjusting.
    Tensioner pictures and notes in my albums............I said that earlier.........
  3. #138
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Ok thanks I just saw the white on the belt just wasn't sure if something was wrong.thanks
  5. #139
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    So how important is the air deflector that goes under the radiator ,I can save a few dollar and order from Chris and wait for it to get here I can go to the dealer and pay full price and have it on today .I know its part of the cooling system but never noticed it doing this last year.its going to be in the 100's again the next few days.
  6. #140
    68
    81,894
    It's highlighted right at the bottom of everyone of his posts.
  7. #141
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A few extra days won't hurt.
  8. #142
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    There is a junk yard that has some Cadillacs what years would the air deflector be compatible 99-04 Seville any other models in the Gm family?
  9. #143
    Sep 2010
    East Boston MA.
    29
    26,325
    '98-'04 Seville. Either SLS or STS.
  10. #144
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Well I found an air deflector at a junk yard for $20 just need to get the push pins.it looks like on GM parts direct it uses two different push pins?
  11. #145
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Use the ones i sent in the PM 14093088 ... might as well just go to the nearest dealer
    you can probably get similar (generic) ones cheaper at any old parts store also
  12. #146
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Thanks Chris, so I can use the same pins cause on GM parts direct it shows two different ones #16$ 17 I think
  13. #147
    Sep 2007
    Wilmington, NC
    13,986
    it does show 15 of #14093088 but also 4 of #11518017
    the second number is basically a bit beefier when it's not expanded so it would go into a larger hole
  14. #148
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I must be missing something cause I only found 13 holes is there a diagram for where there go.
  15. #149
    Feb 2006
    55,857
    Maybe forward into the plastic fenderwell liner at the bottom edge.
  16. #150
    68
    81,894
    One or two missing pins won't matter a bit. I think I have two missing.
    There are two that go in sideways where it molds around the cradle frame.
  17. Remove Advertisements
