Problem with battery
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By MoistCabbage
Cadillac Seville / Cadillac Eldorado Forum Discussion, Problem with battery in Past Cadillac Vehicle Discussion; I bought new battery nearly 2 years ago and now hold just 2 days and is dead if I not ...
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    I bought new battery nearly 2 years ago and now hold just 2 days and is dead if I not use a car.
    Probobly take some power,How to check that?On battery multimiter check?How many amp is normal?
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Problem with battery
    Charge it up, then have it load tested. Cable lugs corrode.
    69
    82,180
    Might also pull the DTC's and check for a power drain with the car off.
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    You might just have bad battery. Unhook it at home and check after couple days. may just not be holding a charge. You need to see it holding at least 12 volts after sitting for a day or so.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,571
    I'm with rodnok on this one -
    charge the battery - let it sit a couple hours - then check the voltage -
    after a couple days - check the voltage again -
    that will tell you if you have a battery problem or something draining the battery
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Today I check what What draining battery,I done multimeter test on my + battery and showing 1amp when everthing is off,when I removed radio fuse go down to 0.75amp.
    It is too much.....Something start draining the battery.
    I remove my cluster(was burn) and waiting for other one(I can't find for my car made in mexico)so I don't have any display on cluster and DIC.
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    ok,I checked all fuse and problem was on seats.My seat buttom was all the time on.Now is fine,thanx for help.
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Hi
    I think again somethink draining my battery.I removed + and put multimiter to check.I not sure is ok but multimiter show me 0.40 and after 2 min going down to 0.01.
    That is normal?I think first 2 min after locked door show mi 0.40 becouse power door.
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    guys,where I can find doorbell?In Eldorado 1988 is not working but worked.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    A doorbell? Couldn't someone just knock on your window to get your attention?
    The bell in your car is actually a physical bell and striker, somewhere near the glovebox. I'm not sure exactly where, but I'd start by removing the glove box (liner).
    basscatt likes this.
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Did you know how this look?
  14. Remove Advertisements
