eldorado interior panels - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 78
Like Tree10Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, eldorado interior panels in Past Cadillac Vehicle Discussion; Lifer, Thanks for the update. I'll try it and let you know. Jim Originally Posted by Lifer Here is an ...
  1. #16
    jammgm's Avatar
    jammgm is online now Cadillac Owners Fanatic
    Automobile(s): 2013 CTS Luxury, 1998 Eldorado ETC Crimson Pearl
    Mar 2011
    West Haven, CT
    55
    373
    Re: eldorado interior panels
    Quote Originally Posted by Lifer View Post
    Here is an update to using Velcro to hold things like door panel and interior item. First of all, it is an easy fix, it does hold, well, and if you did not know where it was placed, you might say some non-church-going words when you tried to remove the panel normally.
    With that said, I discovered a minor problem with the heavy duty Velcro hold the bottom and non-hinge side of my driver's door. I used the adhesive that was already on the Velcro strips when I installed it. It made the job easy, and a secondary adhesive is not necessary, as we are not carrying a hanging, weighted load, just holding things together. When my car is out in the hot sun (this is Texas and our summers are above average) the adhesive drips out onto the carpet retainer, leaving a sticky mess. I used some GOOP adhesive remover on a paper towel and it cleaned up. But it did it all summer. The door panel is still secure, does not rattle or flap around, and I have not removed the panel to check the results. This will be done in the spring when I have time - to take the interior completely out again and do some mods and more Dynamating.
  2. #17
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    We'll, I repaired my door panels and went with making new hooks using 1" x 1" x 1/2" metal L brackets and #4 x 3/4" sheet metal screws from Lowe's verus using velcro.
    You need to have skills, time, and patience to fabricate them. Once you make the first one, the others become easier. The plastic in the door at the base where the hook broke off is thick enough to secure them. I also put some shrink tubing on the hook part to keep the metal on metal from rubbing.
    The doors are much tighter and secure verus being held on by just 2 screws.
    I've posted some pictures here and can answer any questions.
    Nach likes this.
  3. #18
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Lifer, How difficult was it to remove the rear interior panels? I would like to re-glue mine but probably have to remove them so I can properly glue the vinyl to the backing. You also mentioned about getting new clips. Are those available at the local parts store? Any suggestions or pictures would be appreciated. I'm a do it yourselfer and having the knowledge to properly remove and reinstall them would be good so I don't permanently break anything. Also, what is Dynamating? I've haven't heard of this? Thanks, Jim
  5. #19
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Lifer,
    Do you have any tips or pictures on how to remove the rear panels you could share? For any clips that broke, where did you get those?
    I want to repair mine and feel removing them to re-glue the vinyl would be the best way to do it. Thank you, Jim
    I have removed the entire interior of my 2001 Eldo, seats, console, carpets,door panels, trim pieces, dash,and rear panels, along with the rear shelf and light. Everything except the headliner. As I did it I ordered all new clips as the ones I removed were usually damaged. Also, you have to be vigilant and quite knowledgeable as there is so much nylon/plastic, that you can destroy without a forewarning.
    Once you have everything out, CLEAN, do the leather treatment, and photograph EVERYTHING in EVERY WAY!!!
    I Dynamated the floor pan and part of the side walls - man, this car has a quiet ride now.
    You will find the rear panels are solid, and made with vinyl over foam and plastic or perhaps fibeglass. Fix what needs fixing aand when you replace everything, take your time, do it in the correct order (RTFM), and again, use new clips. And photograph every step from every angle. Digital photos are cheap, and you will will reveiw them often if you keep the car.
    Plastics (remember the Graduate?) shrink with age, harden when exposed to thinks like body oil, evaporate and crumble. Leather will last forever unless mistreated, exposed to heat, aand UV light. So use treatments regularly to help prolong the enevitable.
    I noticed some guys at cars shows were using "near leather" of something like that which is cheaper that leather and is man-made, for their door panels and trim. It's claim to fame is that is lasts a long time, is not affected by the elments like vinyl or naugahide, and is easy to maintain. Just need to find someone that can match the interior panels in the Eldos and Sevilles with this stuff.
    Happy Trails. Good luck with your interior.
  6. #20
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    I have been away from my home computer for a few weeks, but I have some information on the rear panel removal I will share, hopefully next week.
    Until then, basically, you remove the rear seat lower, then upper (remove trunk panel to access the two screws with a deep 10mm socket), then the carpet retainers (one screw in the rear of each, and pull up, plastic clips holding), then remove the "white knuckle" grips on the side by the rear windows. The covers pop off with a flat tool and then there are screws. Then work the panels out by easing the clips holding it in.
    One tip - remove the passenger seat to make more room to move around.
    Be careful and take your time. I was a watch maker for a few years and I knew a secret regarding watches that applies to cars. The parts come apart in order, and can only go back the same way. Each part is unique and goes back together in order. There are some minor exceptions, but the interior works like a puzzle. Remove this before you remove that.
  7. #21
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Thank you for the tips and information. It sounds like a big job for a weekend.
    For removing the rear seat lower, I assume you push down then toward the back of the car to release the seat from the hooks to get things started.
    For the clips that hold the panels in place, are they similar to the type that hold door panels on where you need that special tool to ease them out? The pins have a stud on them with layered fins to catch behind the hole they insert to so the tool helps ease them out to prevent from tearing them off the panel. Also, are there any screws under the square panels on the arm rests similar to the power window button panels on the doors I need to worry about?
  8. #22
    Lifer's Avatar
    Apr 2007
    Coppell, TX
    905
    Quote Originally Posted by jammgm View Post
    1. The door panels are held in with two screws and must be lifted off. There are no clips that fit into holes to secure them. The electric panel just lifts out, the cover around the lock panel pops off, and there are to screws, one where the lock switch is, and one hidden at the end of the door pocket.
    2. The rear seat cushion is a bit tough. I use a big screw driver and work it under the seat about 6" from the tunnel and lift up. I have done this a dozen times with no damage.
    3. The side panels are held in with clips that usually break away when you remove the panel. New clips can be ordered from www.clipsandfasteners.com/ or similar suppliers. Use the old clip to identify the right one and order a big box. Shipping costs will kill you, so order as many types of clips extra for as many places you find them.
  9. #23
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Thanks for the information. I'll send an update and share some pics when I do it.
    One more thing. You mentioned something about Dynamating? I've haven't heard of this? Thanks, Jim
  10. #24
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Dynamatting is mostly used for aftermarket car audio setups, it helps reduce unecessary vibration mainly trunks get lined with it
  11. #25
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Thanks.
    Quote Originally Posted by vincentm View Post
  12. #26
    Lifer's Avatar
    Apr 2007
    Coppell, TX
    905
    I got my best deal on Amazon for Dynamating. It is a heavy tar-based-like material with an adhesive face and a reflective aluminum side. It cuts with a pair of scissors, easy to put down, and does two main things. It stops panels from vibrating and sending various frequency sounds (think of your door - a big drum; this tends to reduce or stop the vibration) and it reflects heat, making the interior more comfortable. I find it reduce road and tire noise to a very low level, and the deep carpeting, headliner, and upholstery absorbs the rest (leather does tend reflect more than absorb...). One trick is to get a wall paper seam tool - its a wooden roller on a handle, inexpensive item, and roll this over the sheeting as you apply it. Some purists even put an aluminum tape over the seams for a true locked out system.
  13. #27
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Where in your Eldorado did you apply the Dynamating to?
  14. #28
    Lifer's Avatar
    Apr 2007
    Coppell, TX
    905
    After everything is removed from the cabin - seats, console, side panels, carpet retainers, carpet, you clean the floor rear good with soap and water ( DO NOT FLOOD IT, WIPE IT DOWN TO CLEAN THE SURFACE) and then go over every thing when dry with some mineral spirits or alcohol. Again, don't flood, only wipe it down. I will at this point assume (as in mine) there is no rust or flaking paint. If there is, repair that first. When you have good surfaces, apply Dynamat to them and then reinstall the part. What your trying to do is create a new layer of sound retardant under the carpet and the rear seat area. The same with the inside of the doors and trunk. When the interior components are installed, there should be no Dynamat showing, only working.
  15. #29
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    55
    373
    Nice... And after doing all that your car is much quieter?
  16. #30
    Lifer's Avatar
    Apr 2007
    Coppell, TX
    905
    Very. It is worth the effort if you plan to keep your car and drive it often. I only drive mine on the week-ends, but it is a joy to drive. The quiet is worth the price of admission.
  17. Remove Advertisements
