'86 Eldo problems
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, '86 Eldo problems in Past Cadillac Vehicle Discussion; I've got a 1986 cadillac eldorado (yes, with the 4100 in it) with a number of problems. I'm determined to ...
    JSteiner is offline Cadillac Owners Member
    Aug 2003
    Buffalo
    30
    4
    '86 Eldo problems
    I've got a 1986 cadillac eldorado (yes, with the 4100 in it) with a number of problems. I'm determined to fix them one at a time until i have a working car. But there is one problem that really gets in my way:
    My driver information center/climate control is useless. I cannot control my heat/ac, defroster or anything. I cannot get any readings for fuel economy, etc. But the big problem is that i cannot access the OBD-1 codes. I hold off and warmer, and nothing happens. The whole unit is unresponsive. When i first start the car, sometimes it will say good morning or whatever, but then within a few seconds it will jump to "system problem" whether or not my orange "engine control systems" light is on. When it doesn't say "system problem" it's telling me the A/C compressor shut off because there is no R-12.
    Can anybody help? The only code that i continuously pull up on a scanner is he distributor signal fault, and ISC motor fault. I replaced the ISC motor last night, but haven't had a chance to see if the code was repeated. Any suggestions are much appreciated. Thanks
    CadillacMorgue's Avatar
    CadillacMorgue is offline Cadillac Owners Member
    Jul 2003
    phoenix az....damn its hot here
    33
    23
    Re: '86 Eldo problems
    ac control panel.... or you need a new programmer.... another possiblilty is there is a little add lookin Dealy uncer the hood.... i can remeber off hand what it is called but it is up by the firewall on the passenger side...check those for you A/C
