motor mount broken questions - STS 2001 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, motor mount broken questions - STS 2001 in Past Cadillac Vehicle Discussion; Westar has a solid rubber front mount - EM-3083S - I installed it yesterday (along with solid rubber side mounts), ...
  1. #16
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    Re: motor mount broken questions - STS 2001
    Westar has a solid rubber front mount - EM-3083S - I installed it yesterday (along with solid rubber side mounts), NVH is a little bit up but not so bad, I expect it to settle down. Time will tell if this solid mount is any stronger... good news is my mysterious front-right rattle is gone.
    Both my front and front-right mounts had failed, the front right one leaked oil out the bottom but the front one still had oil in it - it had cracked on the top so only leaked when I turned it upside down...
  2. #17
    Mar 2011
    1,277
    As a followup, I replaced the two rubber side mounts with hydraulic ones as the NVH was too much for a Cadillac... and was a lot more shakey than normal at a cold start. (Normal I suppose.) With the aftermarket hydraulic ones I'd say it's back to completely smooth.
    However the front solid rubber mount is staying in, let's see how long it lasts with generous application of the go pedal!
  3. #18
    andrewgrahamwebb is offline Cadillac Owners Member
    Automobile(s): 2000 sts
    Feb 2009
    34
    14
    how does this fit? it has 4 bolts holes on top and bottom ~ the original one just has bolt through the top and bottom
  5. #19
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    Quote Originally Posted by naif View Post
    An aftermarket front hydraulic mount is unlikely to last beyond a few weeks depending on your use of the go pedal....
    Only problem is that RA lists only one hydraulic front mount and it is the DEA which it says is OEM. I am in the same boat and have been driving with a broken front mount since I bought the car just over 3 years ago. Not sure if I want to bother now though lol
  6. #20
    69
    82,396
    Fabricate a set of torque struts and the front mount will last forever.
    http://www.cadillacforums.com/forums...northstar.html
  7. #21
    Fish6543 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Eldorado ESC
    Sep 2013
    51
    1
    My 2001 ESC makes a funny noise out of the front right side when starting from a dead stop. I was told it was a motor mount by the mechanic that just installed the new motor. I know its not the cv joint. Any ideas what it could be???
  8. #22
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,869
    Quote Originally Posted by Fish6543 View Post
    do you have any reason to doubt the word of the "mechanic"?
    did you ask WHY he didn't replace the mount -
    if he knew it was broken?
  9. #23
    69
    82,396
    Not from that description.
  10. Remove Advertisements
