water leaking from hole on bottom of water pump.
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, water leaking from hole on bottom of water pump. in Past Cadillac Vehicle Discussion; noticed a leak, seen it coming from where the water pump sits in the housing, noticed there is a little ...
    turbol15 is offline Cadillac Owners Enthusiast
    Automobile(s): 97 eldo,2011 cts-v
    May 2010
    New york
    673
    noticed a leak, seen it coming from where the water pump sits in the housing, noticed there is a little hole on bottom of water pump and bingo thats where it is coming from. pump was replaced 2 years ago
    69
    82,173
    Re: water leaking from hole on bottom of water pump.
    Sounds like the shaft seal is leaking. Time to replace it again. What brand did you use? New or rebuilt?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    Eldorado or CTS ? Never seen a weep hole on a Northstar water pump capsule. I'm sitting here with a new AC Delco capsule in my hand and there's no weep hole - and if the pump was installed in the water crossover/pump housing you couldn't see one anyway.
    May 2010
    New york
    673
    It's not a gm one. In fact I noticed on eBay the pump that may have been used. That one has a hole also.Prolly rebuilt crap
    Feb 2006
    56,590
    I'd be scared to rebuild one of these - the whole thing is pressed together - impeller, seals, pulley. Hah !!! Better to spend the $50 for a new unit !!!
    Get this - both pumps I have on the shelf - new AC Delco units - are sticky-stamped "Made in China".
    May 2010
    New york
    673
    disgusting
  9. Remove Advertisements
