cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1998 Seville STS ECM-Modules Issues in Past Cadillac Vehicle Discussion; Please Help, Reverse lights only work & Fuel Gauge goes to Zero 1.5-2 minutes after battery reconnected, I have an ...
    makavelli1 is offline Cadillac Owners Member
    Automobile(s): 1998 seville sts
    Mar 2011
    32
    5
    Unhappy 1998 Seville STS ECM-Modules Issues
    Please Help, Reverse lights only work & Fuel Gauge goes to Zero 1.5-2 minutes after battery reconnected, I have an engine misfire (P300) many faults too many list almost like the brain that communicates with all the module is bad, any help much appreciated before I send this ride to the Junk Yard (1998 very low miles its a shame)
    thx
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    2010
    Many
    basscatt's Avatar
    basscatt is offline Cadillac Owners Connoisseur
    Automobile(s): 89 Coupe DeVille, 95 Sedan DeVille, 03 SLS
    Feb 2004
    Minnesota
    60
    1,702
    Re: 1998 Seville STS ECM-Modules Issues
    Quote Originally Posted by makavelli1 View Post
    thx
    OK - so everything went haywire after the battery was reconnected - why was battery disconnected?
    Is the battery good? Has it been tested? Load test done?
    What is the voltage displayed in the DIC key - engine off?
    What is the voltage displayed in the DIC with the engine running?
    Could be a PCM brain fart - clear all the codes and see what comes back.
    Mar 2011
    32
    5
    Hello,
    I disconnected the battery because a previous thread said it would reset the modules and his system all worked, I went to the boneyard and replaced the Rear Interface Module and still have the same problem, it all works when the battery is reconnected for 1.5mins..then all goes haywire, wondering if the main computer is conducting a self check and it takes about 1.5 minutes to fault out. Thanks for replying
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    maeng9981's Avatar
    Automobile(s): 10 SRX, 00 SLS, 99 Deville 50-year Anniversary
    Mar 2009
    Dallas, TX
    20
    2,302
    Is your battery healthy? You skipped the most important test Basscatt told you to do.
    Mar 2011
    32
    5
    Okay let me start over, I bought this vehicle with fuel guage, reverse light inop. After a couple of weeks I would try and start the car and the battery was dead, I bought a new battery and still the car would have a dead battery after a day or so, troubleshot and pulled fuses until I found that the problem was a draw on the CVRSS line, I left the fuse out and the battery holds now. I then replaced the Rear Interface Module that I got from the junk yard and still I have no fuel guage and reverse lights after reconnecting the battery ( I disconnected the battery just trying to see if it would reset the modules) because I have so many different module faults it leads me to think that all these modules talk to a main computer that might be causing all others to fault out/conflicts. BTW: I still have not repaired the CVRSS issue but want to work on one at a time. Any help is appreciated and willing to try many thanks
    MoistCabbage's Avatar
    MoistCabbage is offline Cadillac Owners Master
    Automobile(s): Crimson 2001 Seville STS, 1990 Seville (RIP)
    Sep 2010
    East Boston MA.
    24
    6,855
    What codes are you getting? LIST THEIR DEFINITIONS as well.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    20
    2,302
    A low battery, or disconnecting the battery will bring a lot of false codes.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
