engine light.. quotes code 121... solution please
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, engine light.. quotes code 121... solution please in Past Cadillac Vehicle Discussion; i have a problem with the engine start and shut off automatically.. i have an engine light that shows quote ...
    captdan is offline Cadillac Owners Member
    Automobile(s): 2004 sts
    Dec 2011
    53
    1
    i have an engine light that shows quote generic code 121..
    and my scan tool tells me pedal position A sensor..
    where do i find that????
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: engine light.. quotes code 121... solution please
    You may get a better answer, quicker in the the Seville forum. Most of the crowd here has 2005 & up STS.
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    Whoops, missed that on the first read, thanks EChas. Moving thread to other area.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Forget the scan tool, go to the top of the Seville/Eldorado page, and read the "sticky" on how to pull DTCs. List any codes you may find, AND their definitions, here (there is a link within the sticky with definitions).
    Interesting: your profile says 2004 STS, only the Seville SLS was available in '04. You do have a Cadillac Seville STS, and not an '05+ Cadillac STS right?
    Submariner409's Avatar
    Submariner409 is online now If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,598
    No such thing as a 2004 "STS" (Seville Touring Sedan) unless it is a 2003 that was shipped overseas and titled in the 2004 model year. The driver's door sticker will have a latest build date of 06/03 - all STS production ceased in mid-June of 03 while SLS continued to 12/03, 5 months into the "2004 model year".
    The code and definition makes no sense whatsoever - you need to use the car's built-in code system. Codes will display as a system, number, and timing - as in P 0385 C = Powertrain - CKP sensor fault - Current.
  8. Remove Advertisements
