2002 sls problems starter turns motor dont rotate
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 sls problems starter turns motor dont rotate in Past Cadillac Vehicle Discussion; I have replaced both crank sensors, camshaft, and starter. the starter will turn over but motor does not. Have turned ...
    2002 is offline Cadillac Owners Member
    Automobile(s): 2002 sls
    Nov 2011
    5
    I have replaced both crank sensors, camshaft, and starter. the starter will turn over but motor does not. Have turned over with wrench.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    Re: 2002 sls problems starter turns motor dont rotate
    This section is for RWD/AWD STSs and not the old sidewinders like yours.
    Don't mess with Binky Bear!
    Nov 2011
    5
    Im Sorry how do I move It.
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    That would be my job.
    One relocation coming up...
    Nov 2011
    5
    2002 sls starter turns motor dont
    I need some help. Car quit going down road, I have changed both crank sensors the camshaft sensors and the starter. The battery is showing 12.4 volts. I did to jump it. It sounds like the bendix not coming out. Any help out there. I did check codes I had a camshaft code but it reset.
    Rich_M is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Seville STS (Sold), 04 XLR, 87 Allante
    Oct 2003
    Skippack, PA
    68
    198
    Sounds like a bad starter. Take it back to where you bought it and get a new one.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    If you are able to turn the engine using crank then a starter should be able to too.
    68
    81,928
    Re: 2002 sls starter turns motor dont
    Starter pinion spins, but does not engage the ring gear? Where did you get this starter?
    68
    81,928
    Please do not double post. Threads merged.
    Nov 2011
    5
    The new starter runs just like the old one. I had the old one tested and it checked good. The bendix did not come out as fast as I though it should so I put a new one on it. Is there something that will not let it turn over as fast as it should. The battery is 2 years old but I charged it and even jumped it still on go.
    68
    81,928
    I am still unclear as to whether or not the starter pinion is engaging the ring gear and not turning the engine or is the pinion just spinning and not engaging the ring gear?
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,374
    sheared the teeth off the starter - not likely -
    or flex plate - also not too likely -
    bad bendix - more likely -
    possibly a broken flex plate - saw one from a N* that cracked through at the mounting bolts - starter spun the broken flex plate but not the motor - you wouldn't believe the noise it made!
    Nov 2011
    5
    just turned over and found flywheel is turning but motor is not.
  16. #14
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Flex plate center has come apart. Not common, but not unheard of. A thread and pictures somewhere in here or Northstar within the past 6 months.
    Requires complete transmission removal. No other way. BIG bucks.
  17. #15
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    You really need to inspect the starter, remove intake.
    The starter solenoid is the relay operated magnet that flips the gear in & out onto the ring gear. The starter drive or gears reduction has failed.
    You may have a bad magnet or power source to the magnet(the small wires)or the solenoid relay may be defective.
    These are the easier less costly repairs. Starter replacement is the more reasonable remedy for any starter defect.
    The worst case senerio is
    #1-the starter mount in the block broken/cracked block...
    #2-the ring gear is broken/cracked at the crank flange which is more common
    #3-ringear teeth section broken out & repairable but requires engine/trans removal for all 3 problems...
  18. Remove Advertisements
