2000 STS Replaced MAP Sensor & MAF now NO Power
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS Replaced MAP Sensor & MAF now NO Power in Past Cadillac Vehicle Discussion; I recently had issues with my 2000 STS and the codes were telling me bad MAP Sensor so I replaced ...
    Caddyismybrand is offline Cadillac Owners Member
    Automobile(s): 2000 STS
    Nov 2011
    1
    I recently had issues with my 2000 STS and the codes were telling me bad MAP Sensor so I replaced it, after the replacement another Code kicks out MAF Sensor so I replaced it, Now when I step on the Gas Car does not move forward with effort power. What could the new problem be?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,193
    Re: 2000 STS Replaced MAP Sensor & MAF now NO Power
    I'll bet the MAF clamps, rubber connector rings, and/or the intake duct and resonator are cracked or improperly installed. ANY air leak at or after the MAF will set all sorts of odd mixture/airflow codes.
    Click on my username ^^^, open my profile. two picture albums, 6 pages of pictures and diagrams - many of our intake systems and sensors
    Hey !!!!!!!! Welcome Aboard....................
    nelson480's Avatar
    nelson480 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade Red Raven
    Nov 2011
    71
    Check for Vac leaks. My intake bolts were looser than hand tight....
