Results 1 to 5 of 5
Thread: 2000 Eldorado strut conversion kit. What should I get?
    XBALL23 is offline Cadillac Owners Member
    Automobile(s): 2000 eldorado
    Nov 2011
    25
    10
    I'm looking for a good deal on a front strut conversion kit for my Eldo. I found a few sources online but I'm not sure if there's something better out there that I'm just missing. I also wanted to know what I would be looking at in replacement costs if I take it too a shop?
    I'm not sure if I'm allowed to post links on this forum but I will happily remove them if they are not.
    #1: http://www.suncoreindustries.com/CAD...ersion-kit.htm
    #2: http://www.strutmasters.com/Eldorado...d-f3nsp-el.htm
    #3: https://secure.hostdepot.com/04/088/...ion-parts.html (is this kit missing the coils?)
    Nov 2011
    25
    10
    Re: 2000 Cadillac Eldorado strut conversion kit. What should I get?
    I'm still looking for some input on this issue of mine. Any useful suggestions would be greatly appreciated.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    FRONT STRUT conversion? Conversion from what? I think the wording on the links you provided has you confused.
    First off, your car does NOT have air suspension. The front suspension uses coil springs and oil filled struts, the struts may or may not be active, but we'll get to that later.
    The rear suspension uses coil springs and oil filled shocks, the difference is that the shocks have an air blather on top, that are inflated by an electric compressor when extra load is added to the rear of the car, to keep it level. This is NOT air suspension. There are conversion kits available for the rear suspension to eliminate the leveling system.
    If your Eldo has CVRSS (continuously Variable Road Sensing Suspension) RPO F45, then you have active shocks and struts with variable damping. The only way to retain this feature is to buy OEM AC Delco replacements. They are VERY expensive. If you do not want to shell out that much cash (or you do not have F45) you can buy any after market strut, no "conversion" necessary. (on an F45 car however, you will have to "trick" the computer into thinking you are using the correct active struts using resistors) I would suggest Monroe. To check if your car has F45, check the list of RPO codes on the label adhered to the underside of your spare tire cover, or look for an electrical connection on the shocks/struts (not the air line to the rear bladders)
    Your other question about one of those "kits" missing the springs: The strut itself is the damper, what absorbs the impact and keeps the car from bouncing like a pogo stick down the road. The spring is what holds the weight of the vehicle off of the ground. When you purchase a strut, you get just that, a strut, no coil spring included. The kits you linked are what is usually called a strut assembly, including the strut, spring and mount. This makes installation easier (or cheaper if you're not doing the work yourself) because you do not have to disassemble the spring/strut/mount and reassemble it with the new strut. If your front suspension is not sagging or uneven from side to side, there is no reason to replace the spring. The mount may still need replacement however.
    BTW, And yes, links are allowed.
  5. #4
    ToledoTSI is offline Cadillac Owners Member
    Automobile(s): 2000 Eldorado ETC
    Dec 2011
    69
    I just purchased and installed the Strutmaster front strut "kit". The strut "kit" comes with a new spring and all the mounts intact. Be sure to specify that your stabilizer link attaches directly to the strut. You may need some type of small press to get the stabilizer link out of the old strut. (Borrow one at AutoZone) My 2000 Eldorado ETC originally had active front struts, meaning they electronically adjusted their stiffness after sensing speed. This "kit" comes with a resistor that plugs directly into the cars wiring harness for each side, allowing the system to think it still has an active front suspension. I've driven Eldorado's since 1970, most of them new. In 1998 I bought my last new one and put 330 miles on it. I loved the car so I bought another; a 2000. These Strutmaster struts make the car ride like new again. I don't think most people will notice the difference. I sure don't.
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    this thread is going on 2 years old -
    too bad you didn't come here FIRST -
    strutmasters usually go for around $400 for the front pair -
    they are ok - but nothing special -
    we could have saved you over $200 by going with Monroe -
    oh well - maybe NEXT time -
    we usually know where the deals are - just ask -
  • You may not post replies
