Page 1 of 7 1234567 LastLast
Results 1 to 15 of 92
Thread: Interior swap, What modules/parts need to swapped from my car?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    I'm swapping the ENTIRE interior from another '01 STS into my car (color change from shale to black). What parts will I need to swap from my car for everything to work properly? Most obvious is the ignition lock cylinder, but I notice the passkey module is mounted on the dash, I'm assuming that has to go onto the "new" dash. What about the reader/exciter on the lock cylinder? The DIM is a must too correct? Anything in/on the steering column? Nothing in the door panels, right? I'd rather swap whatever needs swapping while both dashes are in my living room, rather than in the car. Any insight is, as always, greatly appreciated.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Interior swap, What modules/parts need to swapped from my car?
    Don't change the DIM as it needs to be programmed with your VIN. Actually why you change these (key related) parts anyway?
    Sep 2010
    East Boston MA.
    29
    26,323
    I think you have my question backwards. I'm asking what parts/modules that are original to MY car, need to be swapped into the NEW (to me) interior that I will be installing. I need to swap the lock cylinder so that my key will work in the"new" dash, the passkey module would have to match my car and key as well, right?
  5. #4
    SwampeastMike is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS, White Diamond
    Nov 2008
    Cape Girardeau, Missouri
    53
    782
    Just swap the lock cylinder along with the reader/exciter. Everything will work fine. As the name implies, the reader/exciter merely excites and reads the RFID chip in the key. It then sends the information it reads to the theft deterrent (VTD) module which in turn relays information to the PCM. All of this information must agree with values stored in the modules themselves before the car will start. No need to replace any of the electronic modules--if you do, re-programming will be required.
  6. #5
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by SwampeastMike View Post
    Right. So why would my key/lock cylinder/exciter match the values in the passkey module on the donor cars dash? Would I not have to install MY cars original passkey module into the new dash?
  7. #6
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    The passkey module is part of your instrument panel you have to keep the original instrument panel (IPC) since it it programmed with your VIN and contains your original mileage. All you need to swap is the trim cover on the ignition switch from shale to black Everything else stays in your original dash carrier (not the plastic trim cover that you are changing to black) No modules need to be changed to swap an interior, you keep all your original modules. some of them may be attached to the back of panels you are removing, but just diconnect them from the panel and reattach to the new one.
  8. #7
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Mark C View Post
    ENTIRE DASH (carrier) is being swapped, no plastic trim to remove other than the knee bolster.
  9. #8
    Nov 2008
    53
    782
    The reader/exciter in the ignition switch only reads information. It does not store or compare to any value. It will read any similar key. It is the job of the VTD and PCM to verify that that the information read is valid. Zero need to change any of the electronic modules. Just swap the ignition key cylinder so that your current key works physically. It may even be easier to just swap the trim plate around the ignition switch.
    If you swap the VTD module the car will not start--even if you use the complete cylinder and key from the donor.
    The system is very different than the earlier that uses a resistor in the key. Yours uses an embedded chip that when excited with electromagnetic energy literally transmits a unique identification to the reader. Again, the reader does just that--read--other modules use that information to determine if the key is valid.
    I've studied the FSM and am positive that the reader/exciter can be changed without reprogramming anything. Change the VTD (vehicle theft deterrent) module however and things MUST be re-programmed. A factory fresh VTD will automatically accept the first key used, but unless that key is the original, the PCM has to be reprogrammed. Swap the VTD module with a used donor and it will not accept your original key, nor will the PCM accept a donor key even if the donor key is used with a donor VTD.
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    Is the VTD module what I have been referring to as the passkey module? (located under the drivers side of the dash with a label that reads PASSKEY III)
  11. #10
    Nov 2008
    53
    782
    Yes that is the VTD module. DO NOT SWAP!!!
    The reader/exciter is attached to the ignition key cylinder. If you swap the cylinder you will also swap the reader/exciter. Again, no problem to swap the reader/exciter.
    Also do not swap the DIM (behind the glove box).
    Also do not swap the TTM (tilt-telescope module). It's up and under the dash on the driver side to the left of the steering wheel. If you swap the TTM, differences in personalization settings can require a Tech-II to get things back in sync.
  12. #11
    Sep 2010
    East Boston MA.
    29
    26,323
    So DON'T SWAP the VTD, DIM or TTM from MY dash into the new dash I will be installing? That sounds backwards.
  13. #12
    Nov 2008
    53
    782
    We're backwards in our "swaps". Make certain that the VTD, DIM and TTM from YOUR car stay in YOUR car!
    Also use YOUR radio and YOUR climate control. The radio has a theft-lock and the climate control unit contains an electronic module that must be reprogrammed if changed.
    I can't think of any other modules that might need to be retained, but in general keep EVERYTHING from YOUR car that has purple and/or purple-white wires. The purple and purple/white wires link the main data system and most everything in that system requires some sort of reprogramming with a Tech-II if replaced.
  14. #13
    Sep 2010
    East Boston MA.
    29
    26,323
    I was beginning to think so.
    Ok, now it makes sense. The reader/exciter doesn't matter, all other modules you mentioned must remain with MY car. I was aware the HU had to stay, didn't know the climate controls did as well.
    Anything in the front seats that you're aware of? If not, I'l just be on the lookout for purple, purple/white wires. Thank you for the info.
  15. #14
    Nov 2008
    53
    782
    Nothing I know of in the seats, but don't replace the modules that are underneat the carpet below both of the front seats. The one under the driver seat is the memory seat module; the one under the passenger seat is the airbag module.
    Were you able to remove your headliner intact? If so and if you have a moon roof and the headliner is in good shape, I'd like to buy. Mine has some cigarette burns from a previous owner and my repairs are good but not perfect.
  16. #15
    Sep 2010
    East Boston MA.
    29
    26,323
    I do have a factory moon roof, but since I bought the car, there has always been a slight line/bend right in front of the overhead console. Haven't removed it yet, but I assume the headliner is cracking in that area. I notice that the Velcro used to hold that section of the liner to the roof tends to detach from the steel on many Sevilles I've been in, causing it to sag slightly and crack.
  • You may not post replies
