1973 Eldorado 500 V8 Dummy light help needed
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By carnut
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1973 Eldorado 500 V8 Dummy light help needed in Past Cadillac Vehicle Discussion; I have a 1973 Cadillac Eldorado with a 500 V8 front wheel drive and its been sitting for around 10 ...
    John Tapley is offline Cadillac Owners Member
    Jul 2011
    Moscow, Idaho, United States
    25
    I have a 1973 Cadillac Eldorado with a 500 V8 front wheel drive and its been sitting for around 10 years in a garage. I've gotten it to start and it runs now but the stop eng-oil and gen light stay on when the car is off. When the car is running, all the dummy lights are off. what are some of the possible causes? Any help is appriciated
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Re: 1973 Eldorado 500 V8 Dummy light help needed
    Double post.
    Sep 2010
    East Boston MA.
    29
    26,325
    Key on, engine off- no oil pressure and no alternator output. I believe the lights are working as intended. Unless you mean they stay on with the ignition in the "off" position.
    Jul 2011
    25
    Ya the two lights stay on when the key is in the off position, however when the engine is running, the lights two lights turn off.
    hardley-etc is offline Cadillac Owners Fanatic
    Automobile(s): 94 ETC 78 Eldo 69 Eldo
    Jul 2004
    PA
    170
    switch is going bad
    do you have trouble turning it to the accessory position
    Koooop's Avatar
    Koooop is offline Cadillac Owners Master
    Automobile(s): 300 SRT8, 392 cubic inches of tire smoking power!
    Jan 2005
    So Cal
    53
    8,189
    Sounds like you need to lube the ignition switch.
    Feb 2003
    california
    69
    6,680
    The STOP ENGINE OIL light will come on if the driver door is open. If it stays on with door closed, then I would suspect the pin switch at the door hinge area needs adjusted out or lubed or replaced.
    70eldo likes this.
    Koooop's Avatar
    Jan 2005
    So Cal
    53
    8,189
    Quote Originally Posted by carnut View Post
    I can't say my 73 did this, but it's been a couple of years since I owned it.
    5ohMan is offline Cadillac Owners Member
    Automobile(s): none
    Apr 2014
    none
    1
    Im having a similar concern with a '73 eldo in our shop right now..with drivers door open only, i get a STOP ENG-TEMP light on the dash, no key in IGN at all, just door open. goes out when door closed and, ONLY light that comes on is a WATER light as the car starts to warm up, any help with this one ???
    __________________________________________________ _____________
    Good morning, Your CF account is activated. Please use the Profile and Settings tabs to update your profile to reflect your correct birth date, approximate location, car owned and time zone - or do you really live in London - GMT ?
    Feb 2003
    california
    69
    6,680
    That is a NORMAL function of that era of Cadillac! Its the "bulb check" for that circuit.
    69
    82,163
    I had a '73 Eldo and I do not remember those lights coming on when the door was opened with no key in the ignition.
    Disclaimer:
    It's been a loooong time and I have CRS.
  14. Remove Advertisements
