Results 1 to 2 of 2
Thread: Wheel bearing/brake?
    gregj1006 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Aug 2009
    45
    406
    Is process to change brakes/wheel bearing the same and/or similar to that of an 03' Deville?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Re: Wheel bearing/brake?
    Yes, should be pretty much identical.
    - Remove wheel
    - Remove brake caliper
    - Remove rotor
    - Remove entire hub assembly
    - Replace faulty hub assembly with new
    - Put it all back together
  • You may not post replies
