99 Seville: No Oil Pressure after Cylinder Head repair
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 Seville: No Oil Pressure after Cylinder Head repair in Past Cadillac Vehicle Discussion; I've done the cylinder head bolt thread job on my Miss's 99 Seville and just got everything completed. The Engine ...
    LittleNo is offline Cadillac Owners Fanatic
    Automobile(s): 2000 STS
    May 2005
    Munich, Germany
    34
    100
    I've done the cylinder head bolt thread job on my Miss's 99 Seville and just got everything completed. The Engine runs as it should but has no oil pressure, absolutely no oil at the filter and at the camshafts, and from the noise I guess the timing chain has no oil too.
    Anybody an idea? I've already put in 10 quarts extra oil with no change on the problem.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,267
    Re: 99 Seville: No Oil Pressure after Cylinder Head repair
    Did you follow the GM service Manual exactly concerning locking the crankshaft and setting the harmonic balancer bolt torque ? That balancer hub and its torque setting is what drives the oil pump. Not done correctly and you WILL NOT have oil pressure - guaranteed.
    Good thing this is a roller cam follower engine - you probably haven't fried the cams - yet.
    Jim 99 eldo's Avatar
    Jim 99 eldo is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado 2000 Jeep TJ 2000 Ford SD 4X4 Diesel crew cab
    Dec 2009
    Norco, California
    51
    373
    That bolt needs to be as tight as you can get it and then 1/4 turn more. will be a real bit*h to get it tight now that it is in the car.
    May 2005
    Munich, Germany
    34
    100
    thank you guys, finally I made it
    this is not my first N* and yes, I put the 50 Nm and additional 150° on the bolt.
    For anyone who interests: The problem was the new front crankshaft seal I've put in. A piece of rubber was loose and when I installed the balancer it got between the balancer and the oil pump which forced too much pressure on it. A new seal, installed with a lot of silicone lube (to make sure it survives the install of the balancer) and everything runs fine now.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You put 17.5 quarts of oil in the engine?!?!?!
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    That should be enough to immerse the pump/crank & all the lower galleys.
    Do few no-spark cranks & get some up to the pins & watch through the fill port for oil on the cam bucket flow before you drain the excess out.
    May 2005
    Munich, Germany
    34
    100
    yep, that can help when you have a stuck pressure release valve at the pump, of course it's only a try and must be drained before you go on with the engine running
  10. Remove Advertisements
