85' Eldorado Biarritz Sending Unit Help
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 85' Eldorado Biarritz Sending Unit Help in Past Cadillac Vehicle Discussion; I have a 1985 Eldorado Biarritz and i just put a new gas tank on it and my digital fuel ...
    TaintedSaint56 is offline Cadillac Owners Member
    Automobile(s): 1985 Cadillac Eldorado Biarritz
    Jun 2011
    Isle, Minnesota, United States
    21
    3
    Question85' Eldorado Biarritz Sending Unit Help
    I have a 1985 Eldorado Biarritz and i just put a new gas tank on it and my digital fuel gauge doesn't work, so i went to look for a new sending unit and it will cost me about $150 or so. but with everyone i have found it says without digital gauge. Any idea where or how i can find one with the digital? any help would be appreciated.
    Feb 2003
    california
    69
    6,663
    Re: 85' Eldorado Biarritz Sending Unit Help
    So the gauge worked, then you replaced the tank after swapping over the sender, now it doesnt work? What does the dash display read?
    Jun 2011
    21
    3
    I got the car from a family friend who had it since 95' and when i bought it, it had been sitting for 11 years with a half-full tank of gas and the inside of the tank was full of rust and the car didnt run so i do not know if it worked before i put the new tank on. this is that is displayed
    Feb 2003
    california
    69
    6,663
    That display shows empty. How much fuel did you add to the tank? If its got more than 3 gallons, its grounded either within the sender or the wiring to it. The harness is in a flat plastic sheath that runs over the tank and plugs into the body harness by the rear bumper. Check for voltage at the plug and report back. That same sender is used on the Seville as well and must be a digital sender. Different ohm readings between the 2 senders.
    Jun 2011
    21
    3
    I put 10 gallons in the tank after we put the tank back on and ill check the wiring. Thank you so much it is really annoying having to carry a 2 gallon gas can in the trunk because i dont know how much i fuel i have left and i dont know how accurate the fuel used gauge is.
    aaron79ford is offline Cadillac Owners Member
    Automobile(s): 1985 Seville
    Feb 2013
    37
    1
    Hey did you ever find a sending unit compatible with the digital dash? I just got an 85 Seville with the same exact problem. My mechanic says he can get me the replacement fuel pump no prob, but can't find the correct sending unit anywhere online. Like you said, guessing at my gas level is annoying..
    Feb 2003
    california
    69
    6,663
    The factory service manual lists the diffent OHM readings comparing the 2 senders. I would think installing a proper resistor on an analog sender could make it work?
    xxxxxxxralph85 Guest
    If there is a source for a new sending unit (digital) out there, I can't find it! However, there is a company in Akron that rebuilds them ($139). I have the same problem and am sending a non-working unit to them. For now, I'm using the 'usage' display. Contact me for info on Akron company.
    ""nomorehorses@ruraltel.net""
  11. Remove Advertisements
