Results 1 to 5 of 5
Thread: coolant leaking
    May 2011
    35
    27
    coolant leaking
    1999 sls
    there is a short(10-12in.) ridged pipe coming from the water pump area and it gos up to the intake area of motor. it is weaping coolant, it has what seems to be a flange at both ends and bolts with a single bolt ea. end and is coved with somesort of wrap like foil. i called the dealler in my area to see if there was a gasket or seal to replace. they dont seem to know what this is???? is it for Heater>>??? or to a sensor? what is it called, do i replace the whole thing or is there a seal of some kind.
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: coolant leaking
    You probably have failed crossover gaskets if coolant has made it to the EGR tube. The upper x-over gaskets have an EGR passage(yellow X) that is open but dead heads at the head. From what I see it serves no purpose other than for machining the crossover passage & creates another potential leak point.
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: coolant leaking
    I wouldn't rule out a WP cover leak or thermostat housing leak.
    But if you know coolant is coming from inside the tube this seems the likely source. This could be a give a false diagnosis of a failed head gasket or it could be a headgasket that would cause this. Coolant would have to be going out the ex pipes when the EGR cycles.
    You must have coolant disappearing.
    I have never heard of coolant in the EGR passage happening to anyone here but the gaskets could surely be the cause.
  5. #4
    robtinbc is offline Cadillac Owners Member
    Automobile(s): 1999 Deville and 1988 Belville
    Apr 2014
    Victoria, BC
    42
    3
    Re: coolant leaking
    I have a 99 Deville De Elegance and have the same issue, seeing coolant on the dark grey panel, here:
    It drips from just behind this panel.
    I believe its a hose but cant locate it!! Help.
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    This thread is almost 3 years old.
    Please don't post your questions in multiple threads, you already have answers in yours.
  • You may not post replies
