Tag lights dont work
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Tag lights dont work in Past Cadillac Vehicle Discussion; Need Help, I have a 2001 sts seville my tag lights went out then I replaced the bulbs and now ...
    cJr
    cJr is offline Cadillac Owners Member
    Automobile(s): 2001 sts seville
    May 2011
    5
    Need Help, I have a 2001 sts seville my tag lights went out then I replaced the bulbs and now thy dont come on at all. They do however Flash whenever I unlock the car with the remote, the relay is good heck I even replaced it and i also checked the wiring harrness all the way back to the fuse box. Does anyone have any other idea on what else could be worng with it.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,209
    Re: Tag lights dont work
    Check the wiring harness from the trunk lid lighting where it exits the left trunk hinge bracket - for chafe - and also check the harness ground at the left inner fenderwell ground point. You'll need to peel back the trunk liner carpet.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    i never heard anyone use the name tag lights
    what are they ?
    i know this may sound dumb but also not sure if tag lights is something that was used in the past and is not used anymore or what
    i know what the Dumby light is the tail lights back up lights and turn signals but whats a tag light ?
    oh i think um is it the license plate lights ? or something els
    Feb 2006
    56,209
    Tag lights = those bulbs which illuminate the license tag. In his case, two #194 bulbs in the center top of the trunk lid lighting assembly.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    ah ok the License plate lights that are just above the license plate ok cool
    thanks Sub
    never new they where called tag lights around here when you have a burnt out license plate bulb they just call them your plate lights so never had anyone say tag lights before
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    27
    562
    if you have a multimeter see if there is any voltage at all getting to the sockets...
    cJr
    May 2011
    5
    Thanks, but there is power going to the light bulbs but only when i use my remote to unlock the car and they just flash along with the rest of the car lights but thats it. They do not turn on whenever i turn on the lights
    Feb 2007
    Baldwin, Wisconsin
    27
    562
    I understand that... but try and see what kind of voltage is there if any when the lights are on because there may be a small amount of voltage and we can go from there
    aac123 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville DTS
    Oct 2008
    102
    What did you ever find out? I have the same problem on a 2001 DTS where I have no license plate lights and also the lights on outside of front bumber...
  12. Remove Advertisements
