Problem with 2000 STS RSS c0579
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Problem with 2000 STS RSS c0579 in Past Cadillac Vehicle Discussion; Front struts have been replaced with arnott struts this code just came on a few days ago ?...
    dwight.j.carter's Avatar
    dwight.j.carter is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Seville STS
    Aug 2004
    Des Moines, Iowa, United State
    37
    2,067
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Re: Problem with 2000 STS RSS c0579
    In the future post definition as well.
    C0579 - Left Front Solenoid Circuit Open
    Aug 2004
    37
    2,067
    so does that mean the sensor on the left front one is bad ? I would think i can get a resistor to go in there since the fronts are arnott.
    Sep 2010
    East Boston MA.
    29
    26,325
    No, not the height sensor. There's multiple threads on using resistors, do a search. I'm wondering why theres not a code for both fronts if both were replaced with non active struts?
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by dwight.j.carter View Post
    Your code (C0579) is not a sensor. The code is telling you that the circuit to the strut solenoid coil is open. Since your Arnott struts do not have a solenoid, there was some value of resistance placed in the solenoid wiring (when the Arnott struts were installed) that would mimic the inductive reactance of the solenoid coil.
    That Arnott resistance has failed or become disconnected or something.
    And yes, you can mimic the original strut solenoid coil inductive reactance with a 4.7K Ohm resistor; Radio shack item #217-1124.
    Aug 2004
    37
    2,067
    So get this it's raining here i went out to the store and it isn't coding in the rain. We will see if it comes back when it stops raining here. lol
    Aug 2004
    37
    2,067
    Arnott sent me a new sensor to put on that should fix it.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Is not a sensor, originally is a coil (part of a solenoid) and what Arnott sent you is a resistor (to trick the CVRSS module).
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Check the connection at that wheel.
  12. Remove Advertisements
