2000 STS "Service Suspension System - Speed limited to 90"
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS "Service Suspension System - Speed limited to 90" in Past Cadillac Vehicle Discussion; I just bought my Grandfather's Cadillac....a lifelong dream. I'm 47 and feeling old but I love this car which is ...
    DRCSTS is offline Cadillac Owners Member
    Automobile(s): 2000 Seville STS
    Jan 2011
    54
    4
    I just bought my Grandfather's Cadillac....a lifelong dream. I'm 47 and feeling old but I love this car which is an extra for me. Only 56,000 miles and I only paid $5,000 and all seems well except I do have this readout listed above about servicing the suspension system. I am just looking for some input and/or knowledge before I head over to the dealer.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    Re: 2000 STS "Service Suspension System - Speed limited to 90"
    go here
    http://www.cadillacforums.com/forums...odes-dtcs.html
    see if there are any current codes
    write them down, then go back to the thread and click on the second link... the one under "If your car is a 1996 model or newer, go here:"
    and translate the codes to english...
    then come back here and post up the codes and their definitions...
    without the codes all you can really tell is that there's some sort of suspension problem and it's limiting your speed... you may have a simple cheap fix or an expensive one ahead...
    Jan 2011
    54
    4
    hey thanks...I am totally new to this. I got 5 codes that have History after them and 1 that said Current. Does that mean the one at issue is the Current and the others have been addressed in the past?
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    what where the codes something that i know some guys are gona ask next is if you can post the code and what the meaning is for them so that we dont have to go look it up its easier and can explain the problem
    the current one is usuay the one to be worried about at the time
    so first find out what that code is
    Jan 2011
    54
    4
    The only code that was current was:
    C0577 which I looked up and was "Left Front Solenoid Circuit Low"
    Which means nothing to me
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    I believe you are about to spend another ~$700 fro the car in a left-front strut. Have a look on the strut (remove the wheel) and inspect if the connector that goes to the strut (on the strut not next to the strut) is clean and snug. If it is then check with Rippy for a new strut.
    Read here to understand how is your suspension working and why it cost so much. In fact read the whole Techical Archive is good information.
    Don't ignore the History codes, they may tell you some extra information.
    Sep 2007
    Wilmington, NC
    13,969
    history codes are codes that set some time in the past... usually you don't have to worry about them... especially if they are "U" codes since those ones are communication codes and communications hiccups happen... so as long as you don't have any "U" codes current there's no problem
    this post
    http://www.cadillacforums.com/forums...stem-code.html
    sheds some light on the code
    it's not the exact same code, but similar
    maybe someone else will chime in with a bit more specifics
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by DRCSTS View Post
    That DTC indicates a potential chassis wire harness problem at the LF strut OR a failed strut solenoid.
    You can repair a wiring problem.
    Your options for a failed strut solenoid are limited.
    One would be to replace the strut and taking that option means you really should replace BOTH struts. Pricey.
    Two would be to live with the condition, the messages, and the speed limited condition.
    Three would be to susbstitute a 4.7 KOhm resistor for the LF strut solenoid which would disable the messages but would NOT restore your factory suspension performance.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    you could hook up with rippy for a new strut i forget what they run but i think he can get them for around 600-700 but maybe im wrong
    you couldlso just go grab a used one from a junk yard thats personaly what i would do
    you c pick used ones up in Cleveland all day long for like 75-125 dollars low miles
    Jan 2011
    54
    4
    Thanks...and to others who replied also. Seems like 56,000 miles is early to have to replace strut? I will probably live with it for awhile. The car rides awesome.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    could be anyting from weather to how car was driven before you had it
    these are electronic struts so keep in mind its not like a regular strut
    your right 56k is erly to change one of these struts they should last good till 150k atleast id think
    i have 167 and mine from what i can tell are orginal
    Petey78's Avatar
    Petey78 is offline Cadillac Owners Member
    Mar 2013
    Marina del Rey, CA
    39
    9
    I've got the same exact issue going on....what did you end up having to do in order to resolve the issue?
    Sep 2007
    Wilmington, NC
    13,969
    pull the codes (read the sticky thread for how to pull the codes and how to get their definitions)
    could be many things but the code will point you in the right direction
  16. Remove Advertisements
