1995 SLS Stalling
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1995 SLS Stalling in Past Cadillac Vehicle Discussion; Hi all, 1995 SLS 60k miles. Never showed signs of any problems before. I was coming to a stop at ...
    custom99 is offline Cadillac Owners Member
    Automobile(s): 2005 Eccalade ESV, 2004 Escalade base, 1995 SLS
    Jul 2010
    7
    1995 SLS Stalling
    Hi all, 1995 SLS 60k miles. Never showed signs of any problems before. I was coming to a stop at a stop sign. The car stalled and the service engine light came on. It was very rough to restart and when it did it felt like the car was out of gas. I replaced the fuel filter and it is doing the same thing. It runs fine if you keep it tached up a little bit but if your not on the gas when coming to a stop it will stall. The only work the car has had done recently is a new battery a couple of days ago. Anyone ever experience this? What should I look for?
    68
    81,887
    Re: 1995 SLS Stalling
    Have you pulled the DTC's? Have you ever cleaned the TB?
    Jul 2010
    7
    If the DTC's are the codes, I came up with P36, P52, P67, P95, P109 IO52. I may sound stupid but what is the TB?
    ben.gators is online now Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,179
    TB= throttle body
    Also are these codes in standard format?! how could you come up with these codes?
    Follow this link to pull the codes and write the codes here.
    http://www.cadillacforums.com/forums...odes-dtcs.html
    68
    81,887
    Be sure to post the codes AND the definitions.
  8. Remove Advertisements
