1978 Seville flooding
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1978 Seville flooding in Past Cadillac Vehicle Discussion; Hi to everyone, and thanks for reading this post. I have a 1978 Cadillac Seville with 350 EFI. CAr was ...
    78cadi is offline Cadillac Owners Member
    Automobile(s): 1978 cadillac seville
    Jul 2010
    1
    Unhappy1978 Seville flooding
    Hi to everyone, and thanks for reading this post. I have a 1978 Cadillac Seville with 350 EFI. CAr was running fine and just shut off while driving. The engine floods profusely with the ECU plugged up. I have already checked the coolant and air temp sensors (both read 1100 ohms), fuel pressure (38 PSI), and pressure regulator is fine. I have a Chiltons guide on this vehicle but it gives no info on troubleshooting the TPS sensor (only adjustment). After a couple of hrs. I noticed one of the TPS mounting screws had fallen out and the other was very loose. The car will flood upon trying to start, if I disconnect the ECU it will start and run until all fuel is spent. With the car running I connect the ECU and it shuts off immediately. Any help will be greatly appreciated. I have experience troubleshooting late model vehicles with plenty of diagnostic equipment but I have no way of connecting to this vehicles ECU. Kind of stuck on his one. Thanks.
    acefrede is offline Cadillac Owners Member
    Nov 2010
    Cincinnati, Ohio
    6
    Re: 1978 cadillac seville flooding
    78Cadi
    Did you ever get to the bottom of your problem? I have a 78 seville that is doing the same thing, I thought you were writing about this one . I have tried a different ECU but it was used and not sure if it was a good one. I have had to change the oil twice now just from all the testing.
    Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Quote Originally Posted by acefrede View Post
    78Cadi
    Thanks
    Most of what's in this Seville forum will be 4.9 or 4.6 Northstar engine - for the 350, try down in Discussions; Engines - there's a 350 forum there.
    hjlint is offline Cadillac Owners Member
    Automobile(s): 1978 Cadillac Seville
    Jul 2011
    Hummelstown, Pa.
    10
    Check for Vacuum at the ECU.Check the vacuum hose back to the engine, no splits, loose or blocked.
    If ok. hook up a hand vacuum pump to the ECU port, as soon as you start the engine, applyy 18 inches of vacuum to this and see f this clears the problem, if not ECU (map sensor)is bad. Be sure there is Vacuum comming out of the engine for that hose.
    68
    81,928
    Re: 1978 Seville flooding
    I suspect it's fixed by now as this thread is 3 years old.
  8. Remove Advertisements
