cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Blower motor or fuse in Past Cadillac Vehicle Discussion; I have a 97 Eldorado with the Northstar engine. Yesterday the ventilation fan just stopped dead. I checked the fuse ...
    vavs is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    10
    Unhappy Blower motor or fuse
    I have a 97 Eldorado with the Northstar engine. Yesterday the ventilation fan just stopped dead. I checked the fuse listing but do not see a fuse that controls the fan. I have read several posts that suggest that the blower motors fail on this model. If that is the case, how difficult is it to replace the blower motor? Or is there a fuse or fuseable link that I am missing? Is it typical for the blower motor to just fail like this?
    The vehicle has 98K miles and tremendous sentimental value, so I would like to keep it in tip top shape. Thanks in advance for any help.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    submariner409's Avatar
    submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 STS/61500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    72
    27,872
    Re: Blower motor or fuse
    Read the entire sticky at the top of the main Seville/Eldorado main page titled "How to pull codes". Practice getting your car's Diagnostic Trouble Codes from the built-in system. Write them all down, noting whether each is Current or History and return to the thread. Use the URL with "obd2" in the address to open a link to code definitions. Use the lines/links in the Master Index box to get definitions of any P,B,C, or U codes present.
    C'mon back..........
    Automobile(s): White Diamond '03 DHS
    64
    53,855
    Yes. Check the Tech Tips section for a tutorial on changing it. Then you can decide if you are up to it. It is similar to the Devilles.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    hardley-etc is offline Cadillac Owners Fanatic
    Automobile(s): 94 ETC 78 Eldo 69 Eldo
    Jul 2004
    PA
    167
    check the maxi fuse box
    on my 94 eldo it is below the standard fuse location
    look in the OEM book for the maxi fuse spot
    if i remember, i believe it is a 50 amp fuse that control 2 things
    Oct 2006
    10
    Submariner,
    Here is the list of the codes. All of them came up as history:
    IPC
    P0603
    B1552
    SDM
    B1159
    B1160
    B1161
    B1163
    U1301
    U1096
    U1255
    TCS
    C1255
    PZM
    B1553
    B1558
    B1983
    U1301
    U1128
    U1169
    U1088
    U1096
    U1016
    IRC
    B1771
    U1255
    U1064
    U1096
    RFA
    B2560
    MSM
    B2119
    B0856
    B1983
    NO CCP
    NO ACM
    NO MMM
    Hardley-ETC I have a fuse box under the hood right on the strut housing but I don't see any fuses that indicate that they are associated with the blower. Is there something special about the maxi-fuse?
    64
    53,855
    Find you code definitions here and take note of whether they are current of history.
    http://myweb.accessus.net/~090/dtcobd2.html
    Jul 2004
    PA
    167
    the maxi boxes are under the fuse location your see now
    there is a right hand and a left hand box
    only 4 or 5 fuses in each
    they are about 1.5 times bigger than the regular fuses you see
    look carefully and you will see the plastic covers will come off
    i am at work now and forgot to look in the oem manual last night
    do you have a oem manual?
    maybe the 97 eldo is a little different than 94, but i think there should still be maxi fuses
    Oct 2006
    10
    I found the maxi fuses under the canopy that houses the regular fuses. There was a 50 amp fuse that was marked for AC fan. It was still intact. I am guessing that the blower motor is bad. Is there a way to check the connector before I get a new blower motor?
    64
    53,855
    Wiggle it and see it the blower comes on. Also visually inspect it. If it looks burnt, the blower is failing (or failed).
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
