cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS Door Lock Problems? in Past Cadillac Vehicle Discussion; I have somehow been recruited into a problem with a '01 STS (a friends dads car) and its got me ...
    1fast4door is offline Cadillac Owners Member
    Automobile(s): none
    Apr 2010
    33
    6
    I have somehow been recruited into a problem with a '01 STS (a friends dads car) and its got me stumped. A few weekends ago while they were heading up north the door locks just started re-locking over and over while driving, every once in a while the Theft Deterrent light on the dash would light. They didn't think that much of it other than being annoying, but the next morning the battery was dead. They got it started and got home alright, and then gave ma a call since I had done some work on his Allante before. When I go there I pulled the codes and got a big long list.
    * AMP -- Amplifier
    B1327 Battery/Source Voltage Low
    U1000 Generic class 2 Failure/ Loss Class2 Communication of DIM
    * DDM -- Drivers Door Module
    B3282 Pass. Door Express Down Shorted to GND
    B3833 Window Position Sensor Circuit
    U1713
    * DIM -- Dash Integration Module
    B1983 System Voltage Low
    * IPC -- Instrument Panel Cluster
    B1004 Loss of Keep Alive Memory
    * IPM -- Instrument Panel Integration Module
    B1652 KAM reset
    * IRC -- Integrated Radio Chassis
    U1064 Loss Of BCM/DIM/SBM Communications
    U1065 Loss of serial communications for class 2 devices
    U1160 Loss Of DDM Communications
    U1016 Loss of PCM Communications
    * MSM -- Memory Seat Module
    * RFA -- Remote Function Actuation
    U1305 Class 2 Bus Shorted to Ground/ Battery
    * RIM -- Rear Integration Module
    B1328 Source/Battery Voltage Too High
    * TTM -- Tilt and Telescopic Steering Wheel Module
    B1982 Battery/Source volts high
    All were in History except the B3833 which was current. Now I am under the assumption that a lot of those are from the dead battery, so I went ahead and cleared all the codes and started it and cycled the door locks a few times. Then pulled the codes again. all that was there was B3833 Current, so once again I cleared all and let it sit for a while.
    In the mean time I looked up the B3833 and found a link ***.justanswer.com/questions/2l2eg-i-have-a-2002-cadillac-sls-with-engine-codes-ddm-3833-pcmp0420
    and did what it said about holding the window up button on both front doors for 10 seconds.
    About a half hour later I went and rechecked the codes and what was there was.
    B3172 Window Up Switch Circuit Low
    After doing some looking on this site I could have thrown these just with the process of setting the express window feature.
    So once again I cleared all codes and walked away for a while and was just watching the car and I could hear the door locks cycling every once in a while and the tail lights were lighting up. It wasn't constant like it was but kinda random from what I could tell. So I let it do its thing for a while and went back to get the codes and there were no codes in memory. At this point I don't know what direction to go and could really use some advice. I am trying to find out about the battery, and may get it tested. From what I have read these cars seem sensitive to weak batteries. The other things in my head are the DDM, BCM, and I think its weird that with these symptoms that there are no VTD codes. I know that I am a noob but I have been lurking for quite a while and there are some seriously smart people here and I greatly appreciate any help that is offered
    George
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    2010
    Many
    2001_Seville_SLS is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Seville SLS
    May 2010
    440
    Re: 2001 STS Door Lock Problems?
    The codes are not related to not setting the express up operation. Here is why: First, all of those codes don't show up together if you don't reset the windows after disconnecing the battery. Second, if the windows were reset and your express up operation , the one touch operation, was working on both front windows when you cleared the codes, then the codes are definately not related to failure to reset the windows.
    The codes along with the haunted door switches indicates a poor electrical connection to the RIM.
    1. Check if pulling the IGN SW fuse #29 stops the problem.
    2. Check the IGN SW fuse for corrosion.
    3. Check the connector at the RIM for a good connection.
    4. Check the power and ground conductors to the RIM.
    The RIM is located behind the right rear passenger seat and is accessed thru the trunk.
    BIG ERN is offline Cadillac Owners Fanatic
    Automobile(s): 98 STS
    Sep 2005
    satellite beach fl
    295
    sounds like a battery thats on it's way out or a bad ground somewhere,i would have the battery checked and make sure the terminals are really clean
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    Automobile(s): none
    Apr 2010
    33
    6
    Thumbs up Re: 2001 STS Door Lock Problems?
    Thanks for the reply(s) {I kinda carpet bombed the Caddy Forums}SLS I had read a couple of posts on here about the second set of codes.
    Quote Originally Posted by thu View Post
    Check codes. You might see a B3833 or B3832 code. This is as ewill3rd described - the door module does not know the position of the glass. As such, it will not express-up and/or express-down. This happens when the battery has been disconnected or for other reasons. You will need to reprogram the window motor's express function:
    1. Press and hold the power window switch until the window is fully DOWN
    2. Continue holding the power window switch for about 3 seconds
    3. Press and hold the power window switch until the window is fully UP
    4. Continue holding the power window switch for about 3 seconds.
    5. Repeat this process for the other front window.
    Quote Originally Posted by JimD View Post
    B3172 can be set if a window switch is held too long as in children of any age playing with the switches. If the window still operates, clear the code and motor on down the road.
    The only time you "need" to check codes is when the ENGINE light comes on OR you get an informational message on the DIC.
    That is why I jumped to that conclusion, because I held the window switches for 10 seconds instead of the three that I was supposed to, thanks for the heads up. I will hopefully have the time to work on the car this weekend. I will definitely start with your suggestions, thanks so much.
    I will also be taking a good look at the battery BIG ERN, Thanks
    George
    Automobile(s): none
    Apr 2010
    33
    6
    Well I picked the STS up on Friday night and have been driving it all weekend 100+ miles and no issues what so ever, no door locking no dead battery in the morning.
    I have a theory...I think he left the car dead for a couple of days this time, knowing that I wasn't going to pick it up until Friday night. I think because of the length of time that it was dead that the battery fully drained and basically hard reset all the computers/modules in the car. Really disconnecting the battery for awhile was something I was going to try anyways, in my experience with computer controlled cars when they flake out that is sometimes a fix.
    I did take a look at the #29 ignition fuse and it was clean, no sign of corrosion whatsoever. I also looked at the battery and it looks brand new, I am guessing no surprise there given its location. The date code looked like 0MG19 and it had a green eye still. If I understand correctly 0=2000 and M=December is that right?
    I didn't want to take apart the trunk to get at the RIM while there was no current issues.
    Thanks for the help guys, I really depreciate it.
    George
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
