Here is the latest in this saga.
When I started this thread the car had 77k on it. Wednesday I took it into the dealership for its 90k service. This is the first time I've had 'professionals' touch the car other than a throttle body cleaning since I bought it with 72k miles on it.
OK, as I just said, a few months ago I thought I'd have the throttlebody cleaned 'cuz I got a coupon in the mail. Thought that might raise the idle enough to stop the light from occasionally flickering. As it turned out, it didn't. All symptoms remained the same as I originally described them.
Now lets get to Wednesday/Thursday (9/16/4). I picked up the car after their service and found as soon as it heated up the light started flickering again. The only difference, now it stayed on more than flickered. Again, A/C on, and at idle.
Oh, I forgot to mention in the off chance the problem might have been the oil pressure sensor (OPS) I had it changed out; $12 part, $110 labor!!!! Oh well....
Since I just picked up the car and only put about 7 miles on it at this point I drove it back to the service manager. They kept it overnight and called me this morning.
1st, at their expense they put in another new OPS. Symptoms remained the same.
Then they said, "Well, its either mechanical or electrical." I figured since the whole damn car runs on a computer, the chances are better that they'd find an electrical problem so I gave 'em permission to test the electronics ($102.00).
Late this morning I got called back to tell me the electronics were fine! No problems except when they tested the fuel gauge circuit the needle wavered from empty to full (it doesn't do that without the test equipment hooked up and running, only when it is hooked up).
The suspicion they voiced in regards to the gas gauge was (in so many words) that the instrument panel may be starting to go bad.
Back to the oil light problem. They said, "Electrics are fine. Its obviously a mechanical problem. That will take an engine disassembly to determine and fix the problem." They went on to say, "With the car on the lift, engine idling, there is an obvious 'clattering' sound coming from the oil pan area. Above idle it disappears.
Here's what I told them. "I'll live with the light flicker." If its mechanical and requires a teardown, then I'll drive it till it REALLY requires a teardown, or new engine.
So, thats where I ended up with this problem.
My opinion is, if you have the same problem, learn to live with it and enjoy the car. Ignore it as long as it always goes off once the car is revved off idle.
I am going to try one more thing which mentioned earlier but never did try, I'm going to run that High Mileage oil in it at the next oil change to see if that has any affect. Whether it does or not, I'll report it here!
Oh, if anyone with this same problem has converted over to the High Mileage oil and seen the problem subside or go away completely, let me know!
Lastly, one more thing came to mind. I've always run Pennzoil 10w-30 in the car. The dealership put in Castrol 10w-30. Maybe there is enough difference between the two brands that is the reason the light stays on more steady than it ever did with Pennzoil. Or, the new sensor is really more precise than the old one. Just more thoughts to ponder.
Oh, total cost for all this "investigation."
Throttle Body Cleaning 92.66
New sensor Installation 149.82
Electrical circuit checkup 102.00
Total! About $350.00! All to try and eliminate the light from flickering on the dash. I hope my experience, and money, helps you save your own money.
Please send contributions to..... hahhahaha
..rickko..
