Driver Side A Pillar Removel
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Driver Side A Pillar Removel in Past Cadillac Vehicle Discussion; Hi, I own a 1998 Seville STS. My Problem is that everytime it rains water leaks from the drivers side ...
    YYYECT1 is offline Cadillac Owners Member
    Aug 2003
    1
    Hi,
    I own a 1998 Seville STS. My Problem is that everytime it rains water leaks from the drivers side A pillar.
    Does anyone know the procedure for removing the driver side A piller cover.
    I removed the visors, but it seems like I have to remove the handles over each of the doors. I cannot pry up the plastic covers on each side of the door handle.
    Do the handles above each door need to be removed?
    Is there a special tool needed to remove the plastic covers on each side of the door handle?
    Any help would be much appreciated.
    Thanks in advance.
    caddyshack24's Avatar
    caddyshack24 is offline Cadillac Owners Enthusiast
    Mar 2004
    Florida
    37
    599
    Re: Driver Side A Pillar Removel
    Like that one guy said on another forum, its prolly your Sunroof drain port that is clogged. blow some compressed air threw them and check the fittings.
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    The A pillar moldings that go along the inside of the windshield pull out from the top, next to the sunshades. They're held in with snap retainers that usually pull away from the molding when you're trying to remove them. Just pull them away from the pillar carefully.
