cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Cadillac Seville / Cadillac Eldorado Forum Discussion, Struts and Pulleys in Past Cadillac Vehicle Discussion; My struts are getting worse by the day. what do you recommend? It seems like the ones with the sensor ...
    kjasey is offline Cadillac Owners Member
    Automobile(s): 1999 STS
    Dec 2009
    Ontario
    40
    86
    Struts and Pulleys
    My struts are getting worse by the day. what do you recommend? It seems like the ones with the sensor wires are more expensive than the ones without. Is the quality of the strut the same or is it the sensor wires that jack up the price. Maybe i could live with the warning lights.
    One more question....drivebelt pulleys . I want to get them all replaced. Do you have an idea what a fair price is for this work? Im not sure which one is noisy...it goes away after a while.....but when i spray the belt dressing on it..the noise gets louder. Its not the belt making the noise and Jake(when he had it) confirmed its probably the bearings. I just assume to replace all of them. My car has 114,000 miles.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    Automobile(s): White Diamond '03 DHS
    64
    53,855
    Re: Struts and Pulleys
    The OEM struts are more expensive because they are electronic (active) vs the none electronic (passive). They have sensors and valves that respond to changing road conditions. Someone (Arnott I think) make a passive strut with a kit to bypass the message. I am not sure about how the ride may or may not change those. Others with more experience will chime in.
    I would locate and replace the offending pulley and leave the rest alone. If it ain't broke, don't fix it. It's probably the tensioner or idler pulley.
    Necrosan is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Eldorado Touring Coupe
    Jan 2008
    MKE
    821
    I'd definitely stay away from arnott/the other expensive air ride replacement sites.
    Everything you need is at your local Autozone for hundreds cheaper, and the same quality.
    You can also just cut your old wires off the old struts, and wire a resistor in-line and plug them back in to defeat error codes.
    Almost too easy.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    Dec 2009
    Ontario
    40
    86
    Quote Originally Posted by Necrosan View Post
    Almost too easy.
    Thats what i wanted to hear. Im gonna hit the autozone in highland park michigan in the next few days.
    Where can i find one of those resistors?
    Dec 2009
    Ontario
    40
    86
    Is this what i need? Just connect the exposed strut wires to each end of the resistor to form a loop?
    Jan 2008
    MKE
    821
    Basically.
    I'm not sure what the resistance of the resistor needs to be offhand, submariner or ranger will probably chime in.
    All you do is plug one side of the resistor to one wire (solder!), the other side to the other wire, then you plug it back in where you unplugged it from the car.
    Make sure all of your connections are water tight.
    Automobile(s): '98 STS; RIP @ 206,xxx
    Sep 2003
    Atlanta area
    4,027
    Radio Shack item #217-1124 (4.7K Ohms) will work on a '99 model Seville.
    Dec 2009
    Ontario
    40
    86
    Thanks guys, monday im going to put in the struts, actually a shop in michigan called Brownies is putting them in for 160. Ill be using the Gabriel Ultra g56509 for the front. The rear struts are fine for now. I'll let you know how the ride was back home.
    ben.gators is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS
    Aug 2009
    In the middle of water!
    2,587
    Quote Originally Posted by kjasey View Post
    I would really appreciate if you share your experiences with new struts. I have some feeling that in near future I need to do some thing with my Suspension system. Seville STS 1999 with 128K miles, and still with original active struts, I guess the car is slowly getting to the point that I should replace struts.
    64
    53,855
    Sub is out of town for the weekend and Ranger has no idea.
    JimD to the rescue.
    N*Caddy's Avatar
    N*Caddy is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac STS (BOSE w/AUX In, Massage Seats, URPAS)
    Nov 2006
    Toronto, Canada
    33
    4,796
    The resistors are 5 KOhms (3W or larger) and should be connected between the two wires going to the OEM strut.
    Sep 2003
    Atlanta area
    4,027
    Quote Originally Posted by N*Caddy View Post
    The resistors are 5 KOhms (3W or larger) ....
    Can we swerve off-topic for a little bit here?
    Since this thread will live for however long cadillacforums.com remains "on the air", I feel an obligation to correct the record on the above comment for future readers. Nothing personal is intended.
    The world-wide (including Canada) manufacturing standard for resistors does not include a value of 5K Ohms.
    Nor is there a standard Wattage value of 3 Watts.
    Did I say "nothing personal intended"?
    Dec 2009
    Ontario
    40
    86
    Ok...its been a long day. Crossing that canadian border is becoming a major pain in the ass. Whatever happened to the gold old days when customs officers were nice and didnt care where you went? Oh well. \
    I got the Gabriel Ultra g56509 struts put in today. $180 with no alignment..the mechanic said there was no need...he scratched in a spot.
    I know now that ive been driving with blowns struts for almost a year because the ride is much smoother and more ridged and greatly improved cornering. It takes bumps much better and sloppy and bounce is gone. The sometimes slap noise i heard on the left is gone and the wooshing/weezing sound on the right is gone. My sway bushing probably dont take as much strain now because its much quieter going over those little (one after the other bumps). No more bouncy bounce on speed bumps. I cant really compare these to my old oem electronic cause they were shot from the start. I think some might complain of the ridged feel but for $83.00 a piece you really cant go wrong...actually amazon has them for $56 a piece..but i didnt want to wait. Some say they need break in time....im happy with them out of box. Great Value..370 total cost.
    The strut mounts were in good shape so there was no need to change them and the alignment is still dead on...maybe even better. Now i just need to soder in the resistors!
    I did idler pulley myself...i think i left about a half gallon of blood on the frame Why they put it tight to the frame is beyond me The weeze is gone and the engine is quieter. The real test will be the winter time. P/S pulley seems a bit noisy but not sure, might be normal.
    Anyone know the Tork for the Idler pulley bolt?? Hope i didnt over do it.
  16. #14
    64
    53,855
    If you didn't break it or strip the threads, you didn't overdue it.
  17. #15
    Dec 2009
    Ontario
    40
    86
    Thanks Ranger....there was a touch of play in the idler pulley after i tightened it and of course once the belt snapped back on...all is tight. I sure wish they would of supplied new brackets with pulley that go on the sides of the pulley...they were kind of rusted. The bolt was in good shape.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
