Air mix door/actuator's technical name - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Cadillac Seville / Cadillac Eldorado Forum Discussion, Air mix door/actuator's technical name in Past Cadillac Vehicle Discussion; send me some pics 2 bigrich831@yahoo.com I need to make the same repair. 15-72654 - Air Inlet Valve Actuator 15-72654 ...
  1. #16
    bigrich831 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    3
    Re: Air mix door/actuator's technical name
    15-72654 - Air Inlet Valve Actuator GM# 89018381 Supersedes: GM# 52492937.
    Add to Shopping List
  2. #17
    2001_Seville_SLS is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Seville SLS
    May 2010
    444
    Access to it is thru the glove box. Remove the glovebox and you will see two actuators. It is the one on the left.
  3. #18
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    There are left and right "temperature door" actuators and a "mode door" actuator that is in control of air distribution.
    Locations vary by model and year.
    There is also a "recirculation door".
    GM doesn't use terms "blend" or "air mix".
    At least not in the manual.
    Pretty much all the doors "blend" and "mix air" so....
  5. #19
    May 2010
    444
    Oops, I just noticed that Bigrich and Pogo have Devilles. After looking at number 47 (GM# 89018381), I don't think they access thru the glovebox like on the Seville. Try the Deville forum for better luck with your questions.
  6. #20
    ben.gators is offline Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,184
    Quote Originally Posted by ewill3rd View Post
    A question, as far as I look at the pictures and also the sockets in FSM, it seems that the both actuators that move "temperature door" and "mode door" are the same part? is this correct? I am asking this since I have IPM B1340 and IPM B1343 codes, the former is blend door, and the latter is inlet door fault. I am trying to buy the both, and looking into the online part listings, it seems that they have been listed as the same part!
  7. #21
    May 2010
    444
    Look your parts up on gmpartsgiant.com. They show the blow up and list the number of actuators required.
    Here is a link to the 99 STS page:
    http://www.gmpartsgiant.com/online/P...xID=6M09054102
  8. #22
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    On the 96 Eldorado's you can access the heat/cool blend door regulator thru the panel that easily opens in the back wall of the glove box and can be manually manipulated if needed.
    You describe a zone problem & that door actuator is easily access after removal of the lower panel just above the pass. side foot area. If you manually move this linkage is will effectively combine the separate zones back to one zone and you are back in business.
    To restore the separate zone function this door actuator will need to be replaced. You can live without separate zones when the part costs $185.00+labor
  9. #23
    Aug 2009
    somewhere good!
    5,184
    Quote Originally Posted by 2001_Seville_SLS View Post
    Thanks for the link, I could locate the blend door actuators, but could not find the inlet door actuator from here!
  10. #24
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Some of them might be the same part number.
    There are many factors, I usually give my parts guys the numbers off the old one so that he can be sure to get me the right part # for replacement.
    Depending on the year/model they MIGHT be the same but usually on most newer cars they all vary.
  11. #25
    May 2010
    444
    Quote Originally Posted by ben.gators View Post
    That is because you have to look at another diagram. It is called component 9. Air Inlet. They want $27 +S&H for it.
  12. #26
    samchury is offline Cadillac Owners Member
    Automobile(s): 2001 seville sts
    Jan 2012
    1
    i have a 01 sts it blows hot air from pass and cold out of drivers when heat is on..you said the drivers side is on top behind the glove box? do you know if that is where mine is at on my 01
  13. #27
    SwampeastMike is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS, White Diamond
    Nov 2008
    Cape Girardeau, Missouri
    53
    782
    The driver side air blend actuator is on the driver side, behind the carpeted panel on the side of the shifter console. There are two actuators in that area--the one towards the front of the car is for the driver, the one towards the rear is for the rear blower unit.
  14. #28
    supah_arod is offline Cadillac Owners Member
    Automobile(s): 2003 Seville SLS
    Apr 2012
    Irving
    31
    29
    All good stuff here. I got a 2003 Seville SLS. I get nothing but heat from the driver side and I live in Texas. No bueno. Passenger side is good. I got a quote from a mechanic I always use, he says roughly 620 and a Cadillac dealership said 680. 5 and 4 hours labor respectively. I dont want to spend that kind of money. I figured i can try and take care of it myself. Can yallhelp me find the location of the actuator on my car? Thanks.
  15. #29
    68
    81,929
    #7 in post #19.
  16. #30
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    I had a similar problem in my 98' eldorado...
    http://www.cadillacforums.com/forums...ash-sound.html skip the first 20 posts and go to the end all of the fixes are toward the end.
  17. Remove Advertisements
