cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Trunk Lid Pull Down issue - seville 96 in Past Cadillac Vehicle Discussion; Need help for trunk pull down issue. The lock release works fine but pull down does not. I checked a ...
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    190
    Need help for trunk pull down issue. The lock release works fine but pull down does not. I checked a fuse called "Pull Down". This fuse is good. I understand that either some relay for pull down motor power supply or motor itself may be fauly. I have no idea which relay is that, where is it located, and how to test. Any ideas how to troubleshoot this issue or how to replace motor. I will highly appreciate your response. I can not park car outside in Chicago as trunk is open for about an inch in snow season.
    Thanks
    John
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    Many
    Automobile(s): White Diamond '03 DHS
    64
    53,855
    Re: Trunk Lid Pull Down issue - seville 96
    Check the contacts on the switch next to the motor and the switch itself for starters.
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    33
    1,482
    remove the black platic trim ring around the back of the trunck, after that you can see the wiring.
    That switch, which is what you can push down or let up is what is supposed to operate the motor, it may be shot, the motors i checked all worked, i went throught the junk yard testing them.
    anyway that switch tells which way for the current to flow and when to flow. If its shot it wont tell anything. I got my motor back down by putting 12v to the appropriate wire on the motor, when it was all the way down you can just leave the motor unplugged and your trunk will operate like any other trunk, trunk release will still work.
    then when it not -20 out you can fix or change the switch out if need be, i just use my trunk the way it is.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    Jun 2008
    Chicago, IL
    190
    Cl1986 and Ranger,
    Thank you. I will try to check and move the lid down as proposed by Cl1986. Is there any procedure to check the switch?
    Thanks
    John
    64
    53,855
    I suppose you could pull the switch and hook up a 12v test lamp and see if it gets power when you press on it.
    Jun 2008
    Chicago, IL
    190
    I was waiting for some nice day to fix the Lid pull down issue when I noticed that trunk was some how closed properly. The pull down mechanism is not working. But trunk is closed so I can keep using it
    Thanks
    John
    cl1986's Avatar
    Jun 2003
    South Dakota
    33
    1,482
    LOL, yeah thats what they do....
    I never knew i had a pull down till one day, after 3 years of owning the car, it decided to go up and leave my trunk open......
    downforce's Avatar
    downforce is offline Cadillac Owners Member
    Automobile(s): 94 Eldorado 31k miles
    Dec 2009
    Northern Virginia
    48
    ok...so how do you know if you have trunk pull down? I just picked up a 94 eldorado that I have to slam to close the trunk, but it looks like there is a pretty large black cover over both the trunk lid and the area where is shuts to the bottom of the trunk...would this be the "pull down"? The remote trunk release works fine as does the release from the glove box...
    cl1986's Avatar
    Jun 2003
    South Dakota
    33
    1,482
    all cadillacs have pull downs....at least on this era vehicle,
    in your case, put 12v to the right wire to slightly raise your motor so it shuts nicer, or go all out and replace the motor and switch so it works correctly.
    ya the pull down motor is connected to that hoop at the lower part of the trunk, not the trunk lid
    pop off the 4 plastic buttons and you will see everything
    downforce's Avatar
    Dec 2009
    Northern Virginia
    48
    thanks cl....and you just got a reply on my post about wheels....love those wheels on your car....we have twins...lol
    sztolcaddy is offline Cadillac Owners Member
    Automobile(s): Gone: 93 Seville V8 4.9L SLS, Now: STS v8 RWD'05, Honda Fit
    Nov 2004
    65
    My 93 Seville 4.9's trunk motor also stopped working in an open position. Had to manually turn the hinge down and i bought epoxy in Target and poured it inside the hinge's plastic case and around hinge on top of the metal surface where it goes inside the motor housing. Worked OK as a regular trunk with release.
    Alisonselvig is offline Cadillac Owners Member
    Automobile(s): ajohnson@hpseagles.net
    Mar 2012
    36
    I bought an eldorado that already had the motor removed from the clear trunk latch mount. I just bought a new motor, but the connector I have to hook into that motor doesn't fit. The motor looks like it takes a two-prong but the wires have a flat female 5-prong connector. Is there an adapter or something I'm supposed to have?
    Thank you!
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
