Replacing a side mirror on a 99 Seville
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Replacing a side mirror on a 99 Seville in Past Cadillac Vehicle Discussion; Does anyone know if I need to remove the entire door panel to replace the side mirror on a 99 ...
    cjsuds is offline Cadillac Owners Member
    Automobile(s): 1999 Seville
    Jan 2010
    Does anyone know if I need to remove the entire door panel to replace the side mirror on a 99 Seville or if I can just pull off the plastic piece that covers the three bolts that holds it on?
    Thanks,
    -CJ
    68
    82,072
    Re: Replacing a side mirror on a 99 Seville
    I think that plastic piece is part of the door panel, which would have to come off. Making that piece removable would have made the job too easy.
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    The door panel is very very easy to remove there's 4 screws and the rest is clips, one is behind the door handle that plastice piece behind it comes out, then there's 2 behind the armrest door handle (the one you use to pull the door shut) the piece of leather right behind it is velcroed to the panel and the last screw is at the bottom of the panel exposed,the just pull around the edges and it pops right off, just make sure the window is down when you remove the panel
    Jan 2010
    Haha yeah I guess that would make it too easy. Thanks for the help.
    -CJ
    Discobee's Avatar
    Discobee is offline Cadillac Owners Member
    Aug 2014
    43
    72
    This thread is old but I just wanted to say thank you for the easy to follow instructions. I replaced a passenger mirror just now and it took only less than 30 minutes to remove the door panel, remove the old mirror, put on the newer mirror, and put back the door panel. Which is pretty quick for a "broke-chanic" such as myself. I would've never figured out the velcro flip up panel by the door pull.
  8. Remove Advertisements
