Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: door problems
    barrymarovitz's Avatar
    barrymarovitz is offline Cadillac Owners Member
    Automobile(s): 1997 eldorado etc, N*,4.6L,300hp@6000rpm,50,000miles
    Jan 2010
    chicago
    32
    23
    door problems
    hello,
    I am new here and have lots to ask, my first problem is that my pass door hits a little black nub that is attached to the door frame. now i assume that my door is out of wack but I dont know how to fix plz help.
    '95 eldo etc
    69
    82,272
    Re: door problems
    Can you post a picture?
    Jan 2010
    chicago
    32
    23
    Re: door problems
    i will post the pic as soon as i can having problems with that to.
  5. #4
    Jan 2010
    chicago
    32
    23
    Re: door problems
    I have a problem I'm trying to post pics but i get a message that i cant access it. I'm trying to attach pics to my reply, by clicking the manage attachments tab but i get that message:
    $bbuserinfo[username], you do not have permission to access this page. This could be due to one of several reasons:
    Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
  6. #5
    OTTO's Avatar
    OTTO is offline Cadillac Owners Member
    Automobile(s): 2001 STS
    Dec 2009
    NW of Chicago, IL
    66
    Re: door problems
    My '95 Eldorado driver's side door doesn't close quite all the way. I only drive it on weekends and right now it's too cold out to mess with it.
    When I ever do get around to it, is there an easy adjustment? It fails to close about the very last 1/4 inch. Makes the window whistle when the fan is on high.
    This is my first Cadillac, I upgraded from J body cars. The only thing I don't like about it is that I didn't buy one sooner!
  7. #6
    69
    82,272
    Re: door problems
    Barry, I see you posted the picture problem on the site problem forum. If you don't get an answer there I posted it on the mod & admin page and asked someone to post a reply here. You may not have enough posts to attach a pic, but I'm not sure.
    Otto, loosen the striker on the door jamb and move it inboard just a tad. That should tighten up the door.
  8. #7
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    Re: door problems
    Thanks, Ranger. I was looking at that earlier but, didn't want to try anything yet until I confirmed the proper technique.
    I took her out today for a 3 hour drive to get my sister.....was cruising at 80 on the highway and punched it up to 90 in about 2 seconds!
    That was a blast. Can't wait for some warmer, dryer weather so I can put her to the test on a clear, flat, straight stretch.
    First thing this Spring is a radiator flush, maybe a new t-stat. Too damn cold right now. I work outside enough at work, hometime is to warm up and relax.
  9. #8
    69
    82,272
    Re: door problems
    Yah, a WOT is always somewhat exilerating. Love the sound of a Northstar at WOT. Try it from a standstill or dropping it into 2nd while entering the toll road from a 30 or 40 punch.
  10. #9
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    Re: door problems
    OK, I couldn't stand it so I got on the Carhartts and went out there. That did help but, it seems that the last little 1/16" won't close. Does the latch mechanism wear out? Hard to tell but, it looks like it's plastic.
    The strike post did move in a small amount, so it doesn't whistle through the window seal any more. Also took her to the spray wash to get the salt off of her. The car seems to go faster when it's clean and more aerodynamic...
  11. #10
    Jan 2010
    chicago
    32
    23
    Re: door problems
    OK thanks,
    well until then i will try my best to describe it.
    I have a '97 Eldorado's etc(i might have said 95 before) and on the door frame both pass side and driver side their is a little black nub that sticks out, don't know what it is but it does not matter, and instead of going under it like normal it goes above it making a gap.
    I will also keep trying to upload pics
    thank u
    (this is the other messege i get when i try to upload)
    Invalid Post specified. If you followed a valid link, please notify the administrator
    IMPORTANT: If you received this message immediately after posting, there's a good chance your message was flagged as spam. Please see the following link for more information in regards.
    http://www.cadillacforums.com/forums...m-defense.html
  12. #11
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    Re: door problems
    I looked on my 95 ETC and it doesn't have these plastic/rubber nubs...perhaps try putting the pics on photobucket and then using a direct link?
    PS: Nice avatar!
  13. #12
    Jan 2010
    chicago
    32
    23
    Re: door problems
    At last here they are.
  14. #13
    69
    82,272
    Re: door problems
    Otto,
    If you are talking about the door panel aligning with the fender panel, try loosening that striker again and tapping on it. Maybe you can get another 1/16" adjustment out of it. If not, then perhaps the door was replaced at some point and the front hinges where not aligned properly.
    Barry,
    Oh, those. Frameless windows are a PITA. Best you can do is close the door with the window down a 1/4", then raise it (from inside). When closing it from the outside you might try slowly closing it while pressing the glass under it and then pushing the door closed the last bit. Or maybe lower the window stop inside the door panel a 1/16" and hope it does not cause a wind noise. I fought those damned things for years with frameless windows. Not sorry to see them gone.
  15. #14
    Jan 2010
    chicago
    32
    23
    Re: door problems
    So is it the door that is out of wack or the window? Or worse the frame
    I was hoping to get a point to start at.
    And dont worry if we cant fix this problem got lots more to fix.
    yaaaaaaa
  16. #15
    OTTO's Avatar
    Dec 2009
    NW of Chicago, IL
    66
    Re: door problems
    Thanks again, Ranger. I'll look into proper door alignment technique when I get a set of shop manuals. Probably later into the Summer after work picks up (HVAC Service tech).
    Barry, If you still have the car then (I saw the For Sale sign it the window) I'll see if there is some magical technique in the manual and scan the page for you if so.
  • You may not post replies
