2002 Eldorado Navigation?
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 Eldorado Navigation? in Past Cadillac Vehicle Discussion; Has the Eldorado ever had navigation? My 2002 does not, can I transplant one from another Cadillac? Has anyone ever ...
    nascartamike's Avatar
    nascartamike is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ETC
    Dec 2009
    Fort Hood, Texas
    51
    87
    Has the Eldorado ever had navigation? My 2002 does not, can I transplant one from another Cadillac? Has anyone ever installed an after market navigation or even heard of someone doing it?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Re: 2002 Eldorado Navigation?
    IF the nav screen/unit is part of the Bose head unit then you need a GM dealer to program it with your car's VIN - it's all part of the security and data stream system. I believe a swap without re-program triggers all sorts of no-start and security stuff.
    Get a bean bag dash mount and a Garmin 205W Nuvi GPS. Cheaper and more reliable.
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    stock navigation can not be installed in a eldorado due too the pass key
    sorry
    however i am sure you can install an aftermarket one AS LONG AS you keep the stock deck installed in the trunk and run the audio lines to the new head unit
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Quote Originally Posted by nascartamike View Post
    Too bad you are not located in Toronto area, I would provide you with the OEM Denso NAV unit to test if it works. But my guess is the same as eyekandyboats.inc. I am trying to put this unit in my ’97 STS with no success so far. I am willing to even change the PCM (and engine if required) just to have the NAV unit working.
    Mar 2007
    1,914
    Quote Originally Posted by N*Caddy View Post
    i knew you were crazy about that nav unit but i didnt know how!
    your nuts! lol see ya tomorow!
    Dec 2009
    Fort Hood, Texas
    51
    87
    It sounds like Cadillac really 'over designed' the integration of their technologies. A sound system should be simple; power, ground, speakers, what else does it really need? I did my Suburban last summer, Crutchfield had a easy wiring solution. The dash modification was tough but it came out great. I haven't even pulled the radio on my Eldorado to see what the wiring looks like. It sounds like some of you have and its a mess. I will probably wait until it gets warmer here in Texas to mess with it. My JVC GPS/DVD system in my Suburban is awesome. It entertains me while I'm driving just watching the map. Plus XM, HD and bluetooth are all cool features to have. I know I could have that stuff externally but I want the clean, factory installed look. If you saw my Suburban, you would swear in came from the factory like that.
    Necrosan is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Eldorado Touring Coupe
    Jan 2008
    MKE
    821
    You can definitely do it yourself.
    They make a nice kit too now-a-days so you don't need to futz around with ABS plastic and a dremel too much.
    Don't let these guys scare you into not doing it, it's definitely possible. Also, it is NOT a requirement to keep the OEM HU in the trunk, that's just a personal preference.
    And, FWIW, almost any newer aftermarket double din head unit will top the OEM stuff in looks and performance, if installed right.
    Good luck!
    Mar 2007
    1,914
    if you are refering to the mods you did in your 94 eldo then you headunit is not nearly as intregrated as the 2002 eldorado.
    you have ODB1 computer he has ODB 2 computer.
    also when i removed my stock radio for a couple mins while modifying it i lost control of my lights my memory seats and theft system.
    its up to you.
    your 94 isnt near the same complexity. i know i own a 94 as well
    Jan 2008
    MKE
    821
    I'm not referring to my 94's install, friend of mine has a 99 Seville that he just got fitted up.
    No codes/problems and the car does NOT have the OEM head unit in the trunk.
  12. Remove Advertisements
