No heat at idle
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, No heat at idle in Past Cadillac Vehicle Discussion; On my 2004 Seville SLS there is cold air blowing out heat vents at idle.Engine is at normal operating temp. ...
    jjsmith1 is offline Cadillac Owners Member
    Automobile(s): 2004 SLS
    Oct 2005
    Upstate NY
    11
    No heat at idle
    On my 2004 Seville SLS there is cold air blowing out heat vents at idle.Engine is at normal operating temp. Drive down the street and and it is ok. Coolant seems to be full. Any ideas?
    stevo_x is offline Cadillac Owners Member
    Automobile(s): 99 SLS
    Aug 2009
    31
    35
    Re: No heat at idle
    Heater Core I'm guessing. I had a sebring coupe that would do that. Made it hard to defrost my windows. I got my coolant flushed and it took care of it for a while. Problem came back though.
    Your problem could be something completely different. These sevilles are their own breed.
    69
    82,377
    Re: No heat at idle
    Check the water pump belt tensioner. Then check the purge line.
    Oct 2005
    Upstate NY
    11
    Re: No heat at idle
    Thanks. Gotta start somewhere.
  7. Remove Advertisements
