ABS C1232 with 54 error...
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, ABS C1232 with 54 error... in Past Cadillac Vehicle Discussion; Cadillac seville sts 1998 ABS and TCS is on when I drive above approx 50mph, but it is coming only ...
    maciek123 is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville STS 1998
    Apr 2008
    Warsaw, Poland
    41
    98
    ABS and TCS is on when I drive above approx 50mph, but it is coming only when road is wet. When Im driving slowly or when road is dry everything is OK.
    Apart from wirings shall I check something else?
    I cleared codes but problem is still there.
    Thanks
    Maciek
    Caddyshack100 is offline Cadillac Owners Connoisseur
    Automobile(s): 99STS,2004 Jeep Liberty Renegade,98 Deville RIP
    Nov 2005
    1,054
    Re: ABS C1232 with 54 error...
    It sounds like, water is getting into the wires leading to the left front wheel sensor, look at the wiring for nicks or cuts, or the sensor itself is shorting out.
    Apr 2008
    Warsaw, Poland
    41
    98
    Right, that was the thing I was going to check.
    Thanks
    Maciek
    Apr 2008
    Warsaw, Poland
    41
    98
    Hi
    I checked wiring but nothing was wrong. So then I changed hub and problem is solved.
    Thanks all.
    Maciek
  7. Remove Advertisements
