Transmission from Aurora
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, Transmission from Aurora in Past Cadillac Vehicle Discussion; Hi My car is Cadillac Seville STS 1998 and I think I need again to change transmission... I found one ...
    maciek123 is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville STS 1998
    Apr 2008
    Warsaw, Poland
    41
    98
    Hi
    My car is Cadillac Seville STS 1998 and I think I need again to change transmission... I found one in my city from Oldsmobile Aurora 1996 model 4T80E and one more: Cadillac STS Seville Northstar, 4600 cm3, 1994.
    Is there any chance that any from above will match to my car?
    Maciek
    Papi_MaC's Avatar
    Papi_MaC is offline Cadillac Owners Member
    Automobile(s): 02 Escalade/ 01 DTS/ 95 ETC (For Sale)/SOLD 90 92 95 DeVille
    Dec 2006
    Miami
    32
    98
    Re: Transmission from Aurora
    I believe the Aurora's 4T80-E had the same gear ratio as STS/ETC's.
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    pretty sure the 94 will have different connections, the 96 might work, 96 and 98 are both obd II
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    I think the Aurora was 4.0L with less torque and horsepower - that trans may be the same ratio, but have less clutch plates or be somehow be lighter duty
    Apr 2008
    Warsaw, Poland
    41
    98
    This is what I found:
    The 4T80-E is still in use today, on the Cadillac DTS and the Buick Lucerne (when equipped with the 4.6L Northstar).
    Gear ratios:
    1 2 3 4 R
    2.96 1.63 1.00 0.68 2.13
    Applications:
    3.11:1
    1994–2005 Cadillac Deville
    1993-2002 Cadillac Eldorado
    1993-2004 Cadillac Seville
    2006 Cadillac DTS
    3.71:1
    1996–2005 Cadillac Deville Concours/DTS
    1993-2002 Cadillac Eldorado ETC
    1993-2004 Cadillac Seville STS
    1995-1999 Oldsmobile Aurora Autobahn
    2005–2006 Pontiac Bonneville GXP
    2006 Buick Lucerne V8
    My main doubt is ratio if it is the same as in my car.
    And... Mileage of this box is 200k km (approx 124000miles) Im not sure if not to big...
    Maciek
    Caddyshack100 is offline Cadillac Owners Connoisseur
    Automobile(s): 99STS,2004 Jeep Liberty Renegade,98 Deville RIP
    Nov 2005
    1,054
    The Gear Ratios are the same, 3.73, the Aurora also used the 4T65E-HD on the V6 engines and that is the same as the Grand Prix GTP.
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    721
    my 95 STS, 97 STS, and 98 Concours all had the same plug. If that helps :O
    Apr 2008
    Warsaw, Poland
    41
    98
    Quote Originally Posted by Caddyshack100 View Post
    It means that there two types of transmissions HD and non-HD? But anyway both will be OK for my car?
    This particular transmission if from 4.0L V8 Aurora, some pictures are there:
    http://allegro.pl/item863259660_olds...tom_4t80e.html
    Thanks
    Maciek
    Nov 2005
    1,054
    I am sorry, I did not mean to infer something... The Northstar engine V8 can only use the 4T80E, if your car has the northstar then only the 4T80e can work, the other tranny was for the v6 and will not interchange. Only the 3.71 group will work, again sorry for the misdirection.
    Apr 2008
    Warsaw, Poland
    41
    98
    Thanks a lot caddy! Hope everything will be OK.
    Maciek
    Apr 2008
    Warsaw, Poland
    41
    98
    Im coming back to this topic because now i am going to change my transmission.
    So once again:
    Box 4T80E from 1996 Aurora (4L 250 hp) will work in my 1998 STS (4.6 300 hp)?
    I got information that this transmission will fit and also ratios are the same however for STS transmission is stronger than from Aurora and I will destroy it quickly. Is that true?
    Thanks
    Maciek
  14. Remove Advertisements
