Check engine light getting couple different codes
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Cadillac Seville / Cadillac Eldorado Forum Discussion, Check engine light getting couple different codes in Past Cadillac Vehicle Discussion; ...
    marios caddys is offline Cadillac Owners Member
    Automobile(s): ALL WHITE 91 SEVILLE 93 SEVILLE 90 COUPE DEVILLE
    Dec 2009
    20
    PostCheck engine light getting couple different codes
    Happy Holidays! I have a 1993 Seville with the 4.9, check engine light recently came on and is bringing up some codes looking to fix it, but donít know where to start.
    Po 52 (history) PCM Memory Reset
    Po98 (history) High RPM P/N to D/R Shift under ISC
    Po12 (history) No Distributor Signal
    Po13 (history) Right Oxygen Sensor Not Ready
    And then last but not least
    Po46 (current) Right to Left Bank Fueling Difference
    I recently had my transmission rebuilt about 3000 miles ago and from first to second under mild acceleration it hits pretty hard I hoping that the po98 code is not from this it is still under warranty, thatís not the problem its all the other codes, want to fix the problem just donít know where to start if you guys could help it would be much appreciated Thank you
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    Re: Check engine light getting couple different codes
    History is History don't worry about it
    Not sure about the current code
    Dec 2009
    20
    okay, i just cleared the codes from the system, going to drive it a bit and see what code comes back, Thanks
    Feb 2003
    california
    69
    6,627
    The PO46 will come back, left to right imbalance usually means a vacuum leak on one bank causing it to be lean. Now you need the factory manual to diagnose the code. Too many possibilities to give you a proper diagnosis thru this forum.
    Dec 2009
    20
    The car has been a little bad on gas (put 93 in it) does that have anything to do with the code, and i do have the factory book where do i look for it at, i recently did a fuel system cleaning will this do it or do i have a cracked hose somewhere Thanks again
    Dec 2009
    20
    also my heat has been really weak this winter started not working good but cleaned the connection now just luke warm whats going on with this car?????
    VEGASELDO91 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ELDORADO (R.I.P.); 1995 Sedan Deville
    Nov 2009
    341
    Quote Originally Posted by marios caddys View Post
    In regards to the harsh shifting it may be as simple as a faulty vacumn connection at the modulator. A few years ago my 88 Eldo had the same problem (hard shifting from 1st to 2nd gear) I took it to the transmission shop for a free inspection. A few hours later I got a call telling me the problem was internal and it would cost $650 just to take the trans out and inspect it, I didn't have the funds so I picked it up. I read about the modulator in the Haynes manual and sure enough when I checked it the rubber vacumn line it was dried up and cracked.
    I put a new piece on totally convinced it was not going to help, and it actually fixed the problem immediately!! I never had the problem again for the rest of the time I owned the car and that was over two more years.
    Nov 2009
    341
    I learned through the helpful people on this forum that if the T connector where the heater hose(s) connect to doesn't have the restrictor inside you will not get much hot air. If it is aftermarket there is a good chance that it does not have the restrictor. This may or may not be your problem. Also make sure you have enough coolant in the system so it can reach your heater core... hope this helps!
    Dec 2009
    20
    Thank you i will take a look tomorrow and for the check engine light so far so good the light did not pop back on 50 mile trip to work so hope its all good Thanks again try the heat in the morning
    Dec 2009
    20
    well while driving today 2 codes came back po13 and po46 what the hell are these code I am searching everywhere maybe I am not looking in the right place HELP PLEASE!!!@!
    Dec 2009
    20
    Now the lights went off i filled up on gas and they went off does this have anything to do with the gas iam putting in or does my computer have a mind of its own....
    Necrosan is offline Cadillac Owners Enthusiast
    Automobile(s): 1994 Cadillac Eldorado Touring Coupe
    Jan 2008
    MKE
    821
    Your oxygen sensor is bad according to P013.
    Maybe fixing that will also take care of P046?
    Dec 2009
    20
    okay thank you for the lead I will start there
  16. #14
    Feb 2003
    california
    69
    6,627
    Each time you restart the computer reads the sensors. The light will come back once it sees the malfunction again. Type of fuel has no bearing. A Lean bank code will also set an Oxy sensor code. Determine the right to left bank imbalance first. the Oxy sensor code usually will go away. The codes do NOT tell you what to replace, they tell you what to diagnose. The heater problem should be entered as a different thread.
  17. #15
    Dec 2009
    20
    Thank you for your in put i will start with the o2 and go from there
  18. Remove Advertisements
