Rear Wheel Noise
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Rear Wheel Noise in Past Cadillac Vehicle Discussion; Ok Frist I wanna thank everyone that helped answer all my questions on my 97 sts it runs like a ...
    ryan_day4 is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Jul 2009
    32
    40
    QuestionRear Wheel Noise
    Ok Frist I wanna thank everyone that helped answer all my questions on my 97 sts it runs like a top now ive put 8000 miles on it since oct. and so far its been the best 800 dollar car ive every bought but anyway now when i turn i hear coming from the back wheel a noise like something rubbing almost sounds like the rotor is rubbing the brake pads you only can hear the noise when you turn and the window has to be down I jacked the car up and spun the wheel with my hand it rolled smooth with no weird sounds any help would be great
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    54
    3,516
    Re: Rear Wheel Noise
    Wheel bearing? Grab the wheel with both hands and push/pull to check for bearing play. Jack it up first.
    Jul 2009
    32
    40
    Ok well jacked it up and no play at all so maybe its in the brakes the guy that sold me the car didnt have a clue how to work on stuff i mean he sold it to me for 800 dollars because the ac only blew out of the defrost vents and that was just a vac.. line off and he also told me the brake booster was bad and all that was it had a bust brake line in the front where somone had changed the brakes and left a bolt out of the braket that holds the rubber line and it got into the tire so he had worked on all the breaks i was looking back there today and seen the brakett for the em brake cable was missing a bolt and the caliper looked funny go i took it all off and put it back right so i will drive it and see and let you know thanks for the help
    Apr 2007
    The Ocean State
    54
    3,516
    Usually noise in turns is front wheels not rear. Unless its the rear knuckle issue but I don't know much about that.
  7. Remove Advertisements
