Replace Fuel Pump
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Replace Fuel Pump in Past Cadillac Vehicle Discussion; I Have A 97 ETC Eldorado,I'm Going To Replace To Fuel Pump.Is There A Access In The Truck Or Under ...
    JUMP IN MY KITTY is offline Cadillac Owners Member
    Automobile(s): 97 ETC 89 Coupe Deville
    Jan 2005
    Dallas tx
    46
    Replace Fuel Pump
    I Have A 97 ETC Eldorado,I'm Going To Replace To Fuel Pump.Is There A Access In The Truck Or Under The Back Seat To Get To The Fuel Pump.Or Do I Have To Drop The Tank.Thank You, Have A Merry Christmas
    Cleaner1974 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Eldorado ETC Kathy (deceased), 1996 Eldorado ETC Sylvia
    Apr 2009
    Texas
    42
    112
    Re: Replace Fuel Pump
    hmmm i have read many posts about this. they put in an access port in later year cars...cant remember which year, search for fuel pump replacement and im sure you'll find something.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Eldos, no. Devilles all the way though the 1999 model year, no. Sevilles 92-97, no.
    98+ Sevilles have the access cover in the trunk.
    00+ Deville have the access cover.
    95-04 Auroras have the access cover.
    The Bonneville's have the access cover. Basically anything with this chassis/platform has it. Can't remember the letter definition. Eldorados never did.
    The reason for the access cover: If your car has it, you have to drop the rear sub-frame to remove the tank. This would be too labor intensive just to change the fuel pump module, so GM did something to help us. Thankfully.
    Your Eldo has two straps with 15mm bolts holding them up, one wire harness that needs to be disconnected, and three fuel lines. One is pressure feed, one is return, and the other is the EVAP / vent line.
    It's a P.I.T.A. but do-able.
  5. #4
    Mar 2007
    31
    2,618
    Remember there is also some rubber cushioning on top of the plastic tank to insulate it from the body (to keep it from chafing, making squeaks, wearing with body movement). You may need to get some silicone or something to glue these in place when you re-install the tank. It'll make the job a little easier.
  6. Remove Advertisements
