another driver mirror broken
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, another driver mirror broken in Past Cadillac Vehicle Discussion; I was just reading a recent thread about the failed electrochromatic driver side mirror on here... of course it figures, ...
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,180
    I was just reading a recent thread about the failed electrochromatic driver side mirror on here... of course it figures, mine fails the same week. Went out this morning to clear off the snow and ice, saw the dreaded gold mirror I figure the cold temps caused the mirror's internal seal to break.
    So, does the mirror glass itself get replaced, or am I replacing the whole assembly? And should I get a used one, or is this available from the dealer without replacing the whole thing?
    68
    82,064
    Re: another driver mirror broken
    The mirror alone is replaceable.
    C0RSA1R's Avatar
    C0RSA1R is offline Cadillac Owners Connoisseur
    Automobile(s): '98 ETC Black 90k miles
    Oct 2008
    Lisle, Illinois
    31
    1,061
    Amen, I've been dealing with the same for about a month now. I took it through a harsh automatic carwash at a gas station (I was in a hurry and the car needed a quick job) and the next morning the driver-side mirror had a little patch of gold. It's now entirely gold, but it still functions alright as a mirror. I'm going to wait for winter to end before I replace it.
    Ian-STS99 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Limited Edition
    Dec 2008
    225
    I had to replace the drivers mirror at the end of summer due to the same problem, it cost me over $200.00 just for the glass (heated version).
    Aug 2009
    North Carolina
    1,180
    How does the glass get replaced? Does the mirror have to come off to take the glass out, or does it just pop out?
    68
    82,064
    It just pops out. Turn the mirror all the way out so you can get a grip on it and pop it out. It's held in by 4 ball and sockets. One or each of the 4 directional actuators.
    95ELDOETC is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado ETC
    Sep 2009
    50
    I have the same problem. Where can I get a new mirror?
    Dec 2008
    225
    If you want all the features of the mirror before it failed you need to order a replacement from a GM / Cadillac dealer.
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    58
    1,693
    Quote Originally Posted by 95ELDOETC View Post
    Unless you want to pay dealer list of 238 for the glass alone, the junkyard or Ebay are your only options for a 94 to 97 mirror. There are 2 kinds of mirrors for those years, heated and heated and auto dim. You can buy a whole mirror on Ebay (any color body) for between 40 and 140 and just pull the mirror out and throw away the body (unless you get one that matches your color). you don't need to worry if the mirror is listed as having memory or not if your only using the glass. If you want to use the whole mirror, then you have to match it to your car. ie. if your car has the memory feature the mirror you buy has to have it as well.
    Nightshadow is offline Cadillac Owners Member
    Automobile(s): 2006 White STS 3.6L V6 & 1995 V8 Red Eldorado ETC
    Dec 2008
    Midwest
    38
    46
    Well that would explain why my mirror is in two colors... one is a darker tone and one is lighter, I thought something was peeling off the interior side.
    Mark C's Avatar
    Jul 2007
    58
    1,693
    Becasue the fluid that dims the mirror when electricity is run thru it is leaking out. Theres a layer of fluid between the outer glass and the inner reflective mirror. When the plastic around the mirror cracks (or the glass itself cracks) the fluid starts leaking out. Depending on where the crack is the fluid will keep leaking out until all you have is a clear mirror, or more likely you end up with a mirror that is half dark and half clear. Sometimes you can see the fluid dripping on the door right under the mirror. Its some kind of copper containing fluid.
  14. Remove Advertisements
