1985 Eldorado -- New Owner Has Questions
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1985 Eldorado -- New Owner Has Questions in Past Cadillac Vehicle Discussion; I am working on a few projects with my newly acquired '85 Biarritz. I am hoping you all might be ...
    caddymark is offline Cadillac Owners Fanatic
    Aug 2006
    171
    I am working on a few projects with my newly acquired '85 Biarritz. I am hoping you all might be able to share some insight and advice. Thanks in advance! CaddyMark
    1) Both sun visors are droopy. Is there a way to tighten them so they stay up?
    2) I need to replace information center light bulbs. How should I go about this? A shop? Could I do it? I have the bulbs.
    3) I need to find the rear bumper replacement piece that fits under the license plate. eBay sells the entire replacement (which is in three pieces), but I need only the middle piece (smallest piece). Any ideas on where to find?
    4) If Climate Control works fine and blows ice cold AC but no heat, what could be the causes?
    5) My hood shocks do not hold up the hood. Where can I find these?
    6) Previous owner used synthetic oil (I think Mobil 1). Any recommendations on oil? Thank for your help.... new Eldo 85 owner.
    68
    81,917
    Re: 1985 Eldorado -- New Owner Has Questions
    T connector on the heater hose with no restrictor (if the 4.1 had one).
    Walmart, Menards, Kmart
    Conventional 10W30, but synthetic will do fine if that's your choice.
    Feb 2003
    california
    69
    6,640
    Regarding the heater operation. Locate the heater valve in the heater hose under hood. You will see a small vacuum hose connected to it. You will also see the metal arm coming off the rear of this valve. At 60 degrees displayed this valve gets vacuum to it causing the valve to shut and this arm moves. Any setting above 60 you should see the arm move the other direction opening this valve and the heater hose should be hot on both sides of the valve. All this of course with the engine running fully up to temp. If all that works, then remove the glove box liner and locate the threaded metal rod attached to the climate control box. Start the car and set the temp to 90 degrees. You should see the rod move slowly and smoothly out towards you opening the door over the heater core. Then set the display to 60 degrees and again you will see this rod slowly move back towards the firewall. If it stops, jerks or doesnt move fully in both directions then probably the climate control box is faulty. All this is assuming the car has a thermostat and its a 195 F unit. Post back with what you have seen. I use ROTELLA 20/50 diesel oil in my 84. Have done so on 4 Cads I've owned of this era. There is no "T" in the heater hose on your car.
    Feb 2003
    california
    69
    6,640
    The info center bulbs require removing the plastic wood cover over the speedo, lowering the steering column, reaching in behind to unsnap the speedo cable then remove the screws holding the speedo in. Then gently pull towards you to reach up and disconnect the wire harness, then remove the speed sensor wiring behind the speedometer. Have 2 beers and with the cluster on the workbench replace ALL the bulbs. A 2 hour job at a minimum and at least one bloodly wrist!! NO REAL PROPER WAY TO TIGHTEN THE VISORS BECAUSE THE ROD SLIDES INTO A PLASTIC SLEEVE.
    Aug 2006
    171
    Thank you for this information. I appreciate your help! CaddyMark
  8. Remove Advertisements
