Help!!!!! Power window & service eng light
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Help!!!!! Power window & service eng light in Past Cadillac Vehicle Discussion; I just got a 99 Eldorado 130000 on the clock when i checked the windows out they worked fine got ...
    Anail 1 is offline Cadillac Owners Member
    Automobile(s): cts & eldorado
    Dec 2009
    50
    5
    I just got a 99 Eldorado 130000 on the clock when i checked the windows out they worked fine got it home two days later pass side quit working. The next day it's working again???? Where do I start to look
    To fix this? Now On my way to work I get a service eng light said check gas cap and I did and it was on. Any clues guys
    68
    81,891
    Re: Help!!!!! Power window & service eng light
    Next time the window does not work, try slamming the door while holding the button. If that works, then the motor is probably going bad.
    Pull the DTC's per the sticky at the top of the page to find out why the SES light came on. Be sure that when you put the gas cap on you keep turning till it ratchets a few times. You probably have an EVAP code. A loose gas cap is the most common cause, that is why an EVAP code will always trip that message.
    Dec 2009
    50
    5
    Thanks ranger i'll try that
