95 ElDorado Heater
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 ElDorado Heater in Past Cadillac Vehicle Discussion; I have a 95 ElDorado that is having some heating issues. At first it was just my front blower not ...
    IzzeFizzBizz is offline Cadillac Owners Member
    Automobile(s): 95 ElDorado
    Dec 2009
    31
    95 ElDorado Heater
    I have a 95 ElDorado that is having some heating issues. At first it was just my front blower not working, after grounding the blower control wire, it kicked on. As a Temp. fix I disconnected the battery, re-connected it and it worked for a few weeks. My rear blower has worked the whole time. So has the temp. control. The front blower quit again, so I did the same with the battery, I let it sit overnight, and now the front blower isn't working and the rear is only blowing cold. No ACP codes any time. Both inlet and outlet hoses to heater core were hot, when I checked at 227 degrees. I also cannot manually override the blower speed. Any Ideas? Please Help. Or buy it from me.
    69
    82,173
    Re: 95 ElDorado Heater
    Blower motors where common failures. So much so that they where redesigned. Sounds like your died a slow death.
    Dec 2009
    31
    The Motor is good, I can ground out the control wire and it kicks on just fine.
