No performance options for the northstar engine?
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, No performance options for the northstar engine? in Past Cadillac Vehicle Discussion; According to a previous post I read on here, is it the general opinion that neither with a MAGNA FLOW/FLOWMASTER ...
    joezaier56's Avatar
    joezaier56 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    48
    According to a previous post I read on here, is it the general opinion that neither with a MAGNA FLOW/FLOWMASTER set up in combination with a K&N Air Filter that theres no real perfomance gains to be had with the NorthStar engines from 1998-2004? Is it that minimal a performance gain?!?
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: No performance options for the northstar engine?
    There should be a small gain with the exhaust. The K&N, probably not.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    K&N can actually cost you HP. Drop $1800 on a Corsa exhaust and you can get about 5 HP. No magic chips, no turbos, no superchargers.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,628
    chubbyranger is absolutely correct. K&N is nothing other than high priced advertising that has gotten out of hand.
    Submariner409's Avatar
    Submariner409 is online now If it won't run, install a boombox
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    ..............not to mention that, when using an oiled air filter, there's always the chance of contaminating airflow and idle sensors from excess oil saturation ("If a little bit is good, more must be better......."). Oiled and oil bath air cleaners were the norm back in the 50's and before. With the development of the pleated paper filter, the old oil cleaners went away. A name brand modern pleated paper filter is extremely efficient, filtering on the 20-30 micron level (20/1,000,000ths of an inch) and is also high flow by design. Atmospheric pressure at sea level is about 14.7psi, so absolute vacuum is about negative 14.7 psi (zero) or negative 30 inches of mercury, "inches" being the calibration on a vacuum gauge. A WIX filter for my 2002 STS presents less than 0.25" of vacuum restriction at WOT. Inconsequential.
    Depending on the model of Northstar FWD Cadillac, CORSA makes a limited number of systems. Right now the late Seville system catback is going for about $1180, shipping included, at www.autopartswarehouse.com
  8. Remove Advertisements
