P056 code
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, P056 code in Past Cadillac Vehicle Discussion; Driving to work the other day and got a P056 code which is the transmission speed sensor, and the check ...
    trainwreck68 is offline Cadillac Owners Member
    Automobile(s): 1995 Seville STS
    Aug 2009
    32
    P056 code
    Driving to work the other day and got a P056 code which is the transmission speed sensor, and the check engine light came on. I only get the check engine light when I engage the cruise control. I have 2 questions: 1. Does anyone know if this sensor is just for the cruise or is it also used for the speedometer. 2. I'm assuming it is a sensor that mounts to the outside of the transmission somewhere, does anyone no where?
    Thanks for any input!
    69
    82,262
    Re: P056 code
    That is the $50 sensor buried $2000 deep in the trans.
    Aug 2009
    32
    Re: P056 code
    Unfortunately I just found that out. I should have read other threads before posting.
    Thanks.
    Think I'll go back to Ford or Chevy. Less problems and cheaper to fix.
