No Air From Vents
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, No Air From Vents in Past Cadillac Vehicle Discussion; I have a 1992 sts, and the vents refuse to open! the blower kicks on, you can feel a lil ...
    Hawkjock77 is offline Cadillac Owners Member
    Automobile(s): 1992 Seville STS
    Nov 2009
    39
    1
    No Air From Vents
    I have a 1992 sts, and the vents refuse to open! the blower kicks on, you can feel a lil bit of heat seeping from the passenger side defrost. but thats it. no open vents on any setting...
    68
    81,916
    Re: No Air From Vents
    Defrost is the default mode in case of a vacuum leak (mode doors are vacuum controlled) so you should at least have full air from there. If the blower is working, but no air from anywhere in the car, then I would guess that the HVAC housing on the firewall has gotten brittle and developed a crack or hole and all your air is escaping under the hood. Somewhat common on older cars.
