Stuck in 2nd
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Stuck in 2nd in Past Cadillac Vehicle Discussion; 1996 STS 185K miles, lost 4th gear, than lost 3rd gear, shifts smoothly into 2nd and stays there, have read ...
    pfkaiser is offline Cadillac Owners Member
    Automobile(s): 1996 STS
    Nov 2009
    13
    Stuck in 2nd
    1996 STS 185K miles, lost 4th gear, than lost 3rd gear, shifts smoothly into 2nd and stays there, have read many posts and all point to a soleniod, oddly there are no error codes, any additional thoughts will be appreciated.
    69
    82,381
    Re: Stuck in 2nd
    I'd suspect the shift solenoids even with no DTC's.
    Nov 2009
    13
    Re: Stuck in 2nd
    do you think it in one or both? i have been searcing the forum for tech advise for changing the solenoids. do you know where i can find instructions?
    69
    82,381
    Re: Stuck in 2nd
    It is irrelevant. Change both while you are in there. The kit comes with a hold down strap to prevent it from happening again. Tech Tips section might have a tutorial.
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    41
    718
    Re: Stuck in 2nd
    speaking of shift solenoids, is it easy to tell if they have been done?
    69
    82,381
    Re: Stuck in 2nd
    Only if they where done at a dealer and they pull the service records.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Stuck in 2nd
    Not everything that fails puts up a code. Solenoids are a good example.
    There are threads with good instructions but I no longer have my old bookmarks.
    You have to add the bracket to hold the filter in place so change them both and put the bracket in or you will break the new ones.
    Get an inch/pound torque wrench and use it on the valve body! Overtightening will cause the trans not to shift.
    Nov 2009
    13
    Re: Stuck in 2nd
    do you know the proper torque for the valve body bolts?
    Sep 2003
    Arizona
    3,531
    Re: Stuck in 2nd
    It's low, like 8 to 10 foot pounds, or 96-120 inch pounds I think...
    Hopefully another search may find it. I don't know if it was put into tech tips.
    Some libraries have access to Alldata or Mitchell's on demand.
  12. Remove Advertisements
