99 sts mufflers
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 sts mufflers in Past Cadillac Vehicle Discussion; I know it's been covered and I have used the search function but I want to make sure I have ...
    eXile's Avatar
    eXile is offline Cadillac Owners Fanatic
    Automobile(s): 1999 White Diamond STS Z Rated
    Mar 2009
    Barrington. IL
    26
    258
    99 sts mufflers
    I know it's been covered and I have used the search function but I want to make sure I have all my ducks in a row before I make the plunge.
    The muffler inlet and outlet size IS 2 1/4" correct?
    And both flowmaster 40 delta series as well as super 44s work in our cars?
    I'd reallly like to go to a borla super turbo or pro xs those will work as well I hope?
    How much is installation for this type of job normally? I'm really leaning towarss the borla pro xs mufflers because borla is offered as a upgrade to new cadillacs exhaust systems hats apparently gm certified.
    One more question, I am leaning more toward center/center mufflers instead of offset/center, center/center won't change anything other than more noise right? (which is what I want)
    thanks for the help in advance!
    ~X
    eXile's Avatar
    Mar 2009
    Barrington. IL
    26
    258
    Re: 99 sts mufflers
    BUMP for anyone? :/
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: 99 sts mufflers
    Crickets? I've not seen any posts on exhaust work in quite awhile; its probably one of the least-covered subjects here unless you want to count the Corsa discussions. For most of the stuff I don't know anything about (which is a lot) I can usually at least remember a thread. Drawing a blank on muffler pipe size though. Buy hey, you got a free bump...
    eXile's Avatar
    Mar 2009
    Barrington. IL
    26
    258
    Re: 99 sts mufflers
    Haha thanks chubby, Ive been searching my but off and I keep coming up with conflicting sizes. I at least know for sure that it is either 2 1/4" in and out, or 2 1/2" in and out. Or.... 2 1/2" in and 2 1/4" out or vice versa.... Agh, so aggravating.
    Ranger? Sub? To the rescue on this one please?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    Re: 99 sts mufflers
    You're on your own - the 99 tail pipe sizes are different from the 2000+. Your best bet is to get under the car and use an outside caliper to get pipe OD's because the roll pipe benders used in production jigging do some strange things to pipe sizes.
    Take a hard look at the pic and see what the bender did to the two lower pipes in my old exhaust Y.........
    EDIT: Your car, a 1999 STS, right ? CORSA makes a cat-back for you. Look at www.corsaperformance.com and double check, then look at www.autopartswarehouse.com.
    Here's what you wind up with, and it's good for 20hp+ at redline:
    chacenbra is offline Cadillac Owners Member
    Automobile(s): '99 Cadillac DeVille -- '00 Buick Century Millenium Edition
    Oct 2009
    24
    88
    Re: 99 sts mufflers
    Sub your exaust is G-O-R-G-E-O-U-S
    eXile's Avatar
    Mar 2009
    Barrington. IL
    26
    258
    Re: 99 sts mufflers
    Sub I vote we just trade cars, sound good to you?
    On a serious note, I cannot believe how hard it is to find someone that can weld stainless steel to stainless steel PROPERLY, in my area at least. I have go to 50 miles from where I live currently to get to a shop that will do it. And I am almost positive they are 2 1/2" in and out from the muffler now, gonna look in my factory service manuals to double check. (It will be in there right? )
    Thanks for making me want my exhaust to sound mean even more now Sub.
    Feb 2006
    55,909
    Re: 99 sts mufflers
    The pipe sizes are not in the Helm FSM. I checked. Only references to assemblies, as the entire exhaust system is normally replaced in one piece, from the car flange back.
    My take ?? Wait a while, save up some bucks and early in the spring order a CORSA system. $1185 @ AutoPartsWarehouse, free shipping.
    BTW, look at the system on CORSA's site - it's all straight pipe - no baffles. You shine a flashlight in the front resonator tube and light comes out the tips, but it's quiet except for an idle rumble and at WOT it will wake the dead.
    eXile's Avatar
    Mar 2009
    Barrington. IL
    26
    258
    Re: 99 sts mufflers
    I guess I'll have to save up...
    Taking donations guys!
  12. Remove Advertisements
