Trunk opening tension
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Trunk opening tension in Past Cadillac Vehicle Discussion; When I open the trunk, the opening tension is quite hard and the trunk lid bounces several times. Sometimes the ...
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    When I open the trunk, the opening tension is quite hard and the trunk lid bounces several times. Sometimes the tension gets too hard and it shakes the hole car.
    Is it adjustable or is it something that I have to live with?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: Trunk opening tension
    Remove the trunk carpet liner at the wheelwell areas and you'll see the adjustment brackets for the trunk lid torque rods. If this pertains to your Seville (????) the torque rods run under the rear deck area. Not sure about the Deville.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Thank you Sub, I'll go check that out.
    Feb 2003
    california
    69
    6,640
    And, if you've never done this job it can be dangerous!! The rod is under tension, pryed off, it can be a flying piece of steel! It requires a piece of pipe to contain the rod inside or any body shop could do it at a minimum charge.
  7. Remove Advertisements
