2000 Seville
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 Seville in Past Cadillac Vehicle Discussion; Just had NTB replace just the front disc pads. Now every brake warning light is on the dash board, ABS ...
    buckeyecaddy1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    65
    16
    2000 Seville
    Just had NTB replace just the front disc pads. Now every brake warning light is on the dash board, ABS light on, change brake pads, traction control, stability! Changing the front pads wouldn't cause all that to happen would it? Is there a way of turning all those warning lights off. Or did changing the pads cause all of this. I'm guessing you can reset those???
    69
    82,162
    Re: 2000 Seville
    Take it back. They did not replace or reinstall the brake pad warning wire in the inner pad and did not plug the wheel speed sensor back into the hub assembly.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Re: 2000 Seville
    ...............Bingo !!!
