| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: castrol edge vs mobil 1 extanded performance
11-08-09, 10:56 AM
| | Cadillac Owners Member Cadillac(s): 2001 cadillac seville sts | | Join Date: Jul 2009 Location: Brooklyn we go hard Age: 23 | | | castrol edge vs mobil 1 extanded performance any ideas people on which is better or which would u rather have in your car ??? |
11-08-09, 12:04 PM
| | Cadillac Owners Member Cadillac(s): '99 Cadillac DeVille -- '00 Buick Century Millenium Edition | | Join Date: Oct 2009 Age: 17 | | | Re: castrol edge vs mobil 1 extanded performance In my opinion oil is oil, go to your local auto parts store and find an oil in your viscosity range, in whatever brand you feel comferatable with. slap a WIX or NAPA GOLD oil filter on and your good to go! (NAPA GOLD = WIX)
Personally I use NAPA 10w-30 and a NAPA GOLD filter I dont mess with synthetics or any of that because thats not what the car had in it from the factory. |
11-08-09, 02:50 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: castrol edge vs mobil 1 extanded performance Your engine is spec'd for a name brand 5W-30 oil, either dino, blend or synthetic, whatever floats your boat. Your owner's manual says you can also use 10W-30 but in NY, with colder weather coming, I would stay with the 5W-30 oils.
The 2000+ engines use roller cam followers with static hydraulic lash adjusters instead of the older direct-acting hydraulic followers, so additives and "extended mileage" packages are not needed. |
11-12-09, 05:47 PM
| | Cadillac Owners Member Cadillac(s): 2001 Seville STS | | Join Date: Jun 2009 Location: Maryland | | | Re: castrol edge vs mobil 1 extanded performance I've got an 01 STS with 93k miles and use regular Castrol 5w-30 oil and a WIX filter. No problems and runs great but she does need a quart every 1500 miles or so. |
11-13-09, 12:06 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1988 Allante' (sold), 1984 Eldorado 4100 91 Allante | | Join Date: Feb 2003 Location: california Age: 62 | | | Re: castrol edge vs mobil 1 extanded performance Dont fall for "extended anything". Thats all marketing hype! Quality oil, correct viscosity, quality filter and change every 5,000 miles or 6 months. |
11-13-09, 12:10 AM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: castrol edge vs mobil 1 extanded performance He's got an '01. With highway miles he may get a lot more than that. I do. |
11-13-09, 10:13 AM
| | Cadillac Owners Member Cadillac(s): 2001 cadillac seville sts | | Join Date: Jul 2009 Location: Brooklyn we go hard Age: 23 | | | Re: castrol edge vs mobil 1 extanded performance i have a 2001 cadillac seville sts with 128000 miles on it and if i had to choice i would go with the castrol i looked at the back of the bottle and it surpassed more oils then the mobile 1 had surpassed, it also surpassed all the same oils mobil 1 passed and more. i choose castrol 5-w30 edge oil for my car so far its great but its too soon to tell didnt put 100 miles on it after the oil change. when i reed my users manuel it said to use synthetic and no additives, i use to put castrol 5-w30 with a stabilizer regular oil didnt like it too much  |
11-13-09, 10:29 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: castrol edge vs mobil 1 extanded performance The 2002 manual (pp 6-11 to 6-16) says to use 'starburst" automotive oils in the recommended viscosity range, preferably 5W-30. The only reference to synthetic oils is a paragraph which recommends a 5W-30 or 0W-30 if temperatures drop to -20 degrees F in order to promote cold oil flow.
Otherwise you can use dino, blends, or synthetics, whatever floats your boat. None of the 3 types will void a new car or extended warranty. Additives are not recommended.
Superiority claims on oil bottles or in advertisements are just that: claims. The conditions under which "my oil is better" are so limited that the average daily driver or trucker could never tell the difference what lube oil was in the engine.
Oil stabilizers are great for engines that are laid up for long periods, such as resto rods or trailer queens, cars that see primarily summer/fair weather use, and extended layup such as deployment storage or winter garaging. Stabilizers can be bought just about anywhere, but the best place (least expensive) is a West Marine or large boat store - marine gasoline engines need, and use, a lot of stabilizers due to the nature of the beast: Run like hell all weekend and then sit for a month or so. I do not use stabilizer in the STS. I do use it in my Olds 455's. |
11-13-09, 01:29 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2000 Seville STS, 2005 Nissan Pathfinder | | Join Date: Dec 2008 Location: Raleigh, NC Age: 34 | | | Re: castrol edge vs mobil 1 extanded performance .......all that mentioned above, plus I consider Wal-Mart's Supertech a "name brand"  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
